Optoma HD131Xe, HD (1080p), 2500 ANSI Lumens, 3D-Home Theater Projector - Sub $800 New Budget King? - Page 40 - AVS Forum | Home Theater Discussions And Reviews
 36Likes
post #1171 of 2979 Old 11-17-2013, 11:04 PM
crash2009's Avatar
Try out some live HD Tv channels. HBO, Cinemax, and Starz in 3D. You might never buy a 3D BlueRay again. This PJ appears to turn HD into 3D.
edit: gonna have to eat those words. Smartens up HD, gives 3D from the screen and away. Not much 3D projected into the room.
I just set my DVR to record a Comcast special 3D presentation. It's on the XF3D channel from 6 am to 2 pm. I'll let you know how it is.
edit: Thats more like it, images are projected into the room. Looks like you can reach out and touch them.
Maybe I'll have to give BlueRay another try.
crash2009 is offline
post #1172 of 2979 Old 11-18-2013, 08:58 AM
StrikeOne33's Avatar
Does anyone know if this projector supports these glasses?
ViewSonic PGD150
I have a pair of them already, thats the only reason I'm asking.
StrikeOne33 is offline
post #1173 of 2979 Old 11-18-2013, 11:44 AM
hyperactiveme's Avatar
Quoted: 119 Post(s)
Liked: 72
I just got my eset rf glasses in. I set them up in seconds!
Even though it's kind of gimmicky, 3D does look pretty cool. I noticed that I have to put 3D into SBS mode not auto. No big deal.
Gragg likes this.
hyperactiveme is offline
post #1174 of 2979 Old 11-18-2013, 12:43 PM
crash2009's Avatar
Looks like a "run with whatever works" kinda thing. For me, Comcast HD channels look best with Frame Sequential. Comcast's one and only 3D channel, XF3D displays better using SBS.
I have never been a big fan of "Auto" anyway. Anybody remember when "Plug and Play" first arrived? It was so bad we called it Plug and Pray. Half the time we had to install manually anyway.
post #1175 of 2979 Old 11-18-2013, 02:08 PM
Cyborg_Optoma's Avatar
Quoted: 109 Post(s)
Originally Posted by Cyrano View Post
I have the same question. Here is an Optoma website that shows all their projectors and if you give your PJs info I assume you will get the firmware. http://www.optoma.co.uk/support.aspx I could only find it on the UK site not the USA site.
I still don't know where to find the fw number that my machine has. It should be a selection on the menu.
As for the HD25e fw usage. I saw those posts a while ago too. I guess we'll have to go back and read about it or someone here can clue us in.
Good luck to us both figuring this out. I would like to think maybe we can get even better picture quality with the 25e fw. I don't know. The PQ is pretty good now though.
These aren't the same glasses as the ESG601s but they get excellent reviews. I would try these if I needed a couple more.
(Yet they are non-rechargeables and I prefer rechargables. but they really do get great reviews. After looking around this price is very good.)
Can anyone here recommend them from having used them?
Thanks all.. finally I decided to go with EStar America ESG601 DLP Link 3D Glasses and ordered 4 of them.. hope everything works well....
few questions... so i can just turn on these dlp glasses.. when watching a 3d movie through ps3 or any 3d broadcast from any of the channels through cable.. just need to press 3d mode on pj.. to use it right ?
how about PC? its the same ? just start 3d mode from pj remote and let a 3d content play from PC ? I have a Nvidia GPU attached to my PC.. which is 3d Capable.. options please..
TIA
Still need to get a pringles can so I can cover the lens.. tongue.gif ... Thanks for the tip by nickoakdl..
Cyborg_Optoma is offline
post #1176 of 2979 Old 11-18-2013, 02:48 PM
Cyrano's Avatar
Liked: 90
I did find that I had to select DLP-Link from the HD131Xe's 3D menu. I do not need to do anything each time I use them now.
Enjoy 3D!
Cyrano is offline
post #1177 of 2979 Old 11-18-2013, 04:13 PM
kwk2293's Avatar
Quoted: 46 Post(s)
Liked: 26
They look similar in size and shape to the Estar glasses. I really like the fit of the Estars but they are a little pricey now. I only have two pair so these may be the ones to get.
Of the movies you've seen I have seen Avatar. thought it was really well done. It was realistic. The bodies and objects looked rounded. I watched the Jurassic Rark 3D and it was fun but things seemed flatter. Good depth but not nearly the subtle, rounded reality of Avatar. Just getting started with this 3D stuff and I find this PJ to be excellent.
I just wish the prices on many of the Disc packages wasn't so much. If the popularity grows, the prices will come down. And I buy used copies on Amazon and at f.y.e. and occasionally find good prices.
You could try renting them through mail thats what i do 3dtv corp glasses. Are very good glasses for the price
kwk2293 is offline
post #1178 of 2979 Old 11-18-2013, 05:39 PM
travisbickle's Avatar
+1 I've had great luck renting through 3D-blurayrental
As far as glasses go, I ended up buying six pairs of the MOACC DLP-link glasses. They seem to work perfectly. However, I have no basis for comparison. I turn them on and they sync at 144Hz just fine. The y seem to be a great deal at $23/pair.
http://amzn.com/B00CAO298A
Two months in and I'm still loving this projector.
travisbickle is offline
post #1179 of 2979 Old 11-18-2013, 06:28 PM
Cyrano's Avatar
Liked: 90
Your glasses recommendation is noted. And I wish we could have a real comparison test of all the 3D glasses here at AVSforum. Those of us who have glasses that work are probably a little chauvinist about them. Amazon reviews of yours are great except for one guy for whom they didn't work. The price on yours is very good. And I like the way they look.
They encompass the eye area; they are similar to the ones I use. And they are rechargeable. $22.99 w/free shipping right now. If I need more I'll try them.
Does anyone else use them?
Cyrano is offline
post #1180 of 2979 Old 11-18-2013, 07:29 PM
ngvuanh's Avatar
Originally Posted by kedelbach View Post
I can only compare these to $20 Sainsonics, which my wife prefers for fit but they pinch my nose.
I would like to ask you a question. What is brightness between these $40 bucks glasses and $21 sainsonic?
Just just bought a pair to test them before making decision.
Amazon is sending me a new HD131Xe because of soft focus issue. I just want to see if they receive another batch without this issue before sending to Optoma for repair.
ngvuanh is offline
post #1181 of 2979 Old 11-18-2013, 08:14 PM
kedelbach's Avatar
Last week I put both pairs ($38 Monoprice and $20 Sainsonics) on my head and flipped them back and forth numerous times to compare the "brightness" and 3D "look", and honestly could not tell a difference. As far as I can see they both do a great job at 3D and only filter out an acceptable amount of light.
So, for me, it's purely a matter of comfort. After a few minutes I can somewhat get used to the Sainsonics just prefer the 3DTVCorp ones.
The MOACC's look like they're worth a try as well.
Good luck with your new 131!
Kurt
kedelbach is offline
post #1182 of 2979 Old 11-18-2013, 10:40 PM
sodaboy581's Avatar
Quoted: 25 Post(s)
Liked: 38
Looks like I can probably pick up my projector tomorrow. I was checking the status of my RMA I dropped off on Friday and it was repaired today, I expect a phone call tomorrow to go grab it.
Class: 3 - UA Model: HD131Xe SN#: [removed]
Problem: uneven focus
Received On: 11/15/2013
Repaired On: 11/18/2013
Found: Defocus or couldn't focus on Defocus or couldn't focus on
Repair: Implement TB/RM to upgrade hardware
I'm wondering what exactly "Implement TB/RM" means... either way, it does look like they confirmed the issue and fixed it. Really can't wait to get the projector back in my hands!
Samsung UN65KS800, Denon AVR-X2300W, Polk CS20 Center, Polk Monitor 75T Fronts, Polk TSI300 Rears, Power Sound Audio S1500 Subwoofer.
sodaboy581 is offline
post #1183 of 2979 Old 11-18-2013, 11:25 PM
Quoted: 109 Post(s)
price went down to 746 for those of who bought from amazon.com.. time to get a few buck back... smile.gif
post #1184 of 2979 Old 11-19-2013, 12:52 AM
ngvuanh's Avatar
I would love to get some bucks back.
How would I make it? Call them?
EDIT: Never mind. Just chat with amazon and they refunded me the difference.
I hope the new one is fine. Otherwise, I have to go with repair way.
ngvuanh is offline
post #1185 of 2979 Old 11-19-2013, 01:39 AM
nosdavid's Avatar
How long ago did you buy yours? Bought mine 3 weeks ago, hope I can still get a refund.
nosdavid is offline
post #1186 of 2979 Old 11-19-2013, 06:34 AM
crash2009's Avatar
Does Amazon have some type of "Price Drop" gaurantee?
post #1187 of 2979 Old 11-19-2013, 07:38 AM
terry2's Avatar
Quoted: 33 Post(s)
Liked: 25
Last time I checked they will refund the difference for 14 days after the order is placed for TV's. Depending on who you talk to at Amazon a projector may or may not be considered a TV. I bought a Benq W1070 and the price dropped within a week. They refunded the difference. I returned it (fan rattle) and purchased an Optoma HD25e. The price dropped on it within a week and they refused the refund as the rep I talked to said it wasn't a TV and did not qualify for the refund. Talked to a supervisor later and got the refund.
terry2 is offline
post #1188 of 2979 Old 11-19-2013, 08:11 AM
crash2009's Avatar
Thanks Terry,
post #1189 of 2979 Old 11-19-2013, 09:07 AM
ngvuanh's Avatar
I was on chat with Eric last night and he did refund me for the difference. I bought mine on 10/22.
Sent from my C6603 using Tapatalk
ngvuanh is offline
post #1190 of 2979 Old 11-19-2013, 09:27 AM
Arqui3D's Avatar
About to buy this one. Amazon has it for $746.99 and they give you $50 back in store credit.
Historically, have there been Black Friday deals on these projectors?
Arqui3D is offline
post #1191 of 2979 Old 11-19-2013, 10:24 AM
Moonwalker1982's Avatar
Quoted: 89 Post(s)
Liked: 29
I've been playing some Assassin's Creed III today, and that game has a lot of bright areas, snow, sky etc. During the loading screens, which are completely white i spot a huge green blob effect on the top right. My hope is that it's just something on the wall, but i doubt that. This looks like the green blob/tinge i had on my Panasonic VT30 plasma last year. Anyone else see this? I can also see it when displaying the projector's own white test background
Moonwalker1982 is offline
post #1192 of 2979 Old 11-19-2013, 10:45 AM
sodaboy581's Avatar
Quoted: 25 Post(s)
Liked: 38
If you've got a blob or a tinge on a DLP projector, I'd look at the screen (wall, in your case) or projector lens (check for a smudges).
DLPs don't use panels like Plasmas or LCDs, so you can't really have a uniformity issue like that.
Problems with DLPs you'd get would be a stuck mirror (pixel would be stuck on or off) or maybe a color wheel issue. Then again, I guess you could get a smudge on the color wheel too, if it already had it at the factory somehow.
post #1193 of 2979 Old 11-19-2013, 10:54 AM
Quoted: 89 Post(s)
Liked: 29
I looked on the lens and yes there's actually quite a big smudge on it. I made a photo of it...what you see there shouldn;t be there?
https://www.dropbox.com/sc/5w3pht2q40nuink/tb2nZ-VEyR
https://www.dropbox.com/sc/1m4opf4fm57a2jl/--iKA9PM2c
I tried to remove it gently with a cloth that is used to clean tv screens and such...but it wont go away.
Also the test pattern white of the HD131xe itself is far from truly white...all around it seems more white mixed with green. White backgrounds of the game are more white than the test pattern. odd.
post #1194 of 2979 Old 11-19-2013, 11:25 AM
Cyrano's Avatar
Liked: 90
On my white test pattern it is the same. And I have always noticed the occasional green tinges in small areas of intense white. I always thought of it as an overload of white. I don't think it's a problem. Let others chime in on this.
Just my opinion.
Cyrano is offline
post #1195 of 2979 Old 11-19-2013, 12:19 PM
qposner's Avatar
Ive been wondering the same. THought about pulling the trigger yesterday with Amazon, but am curious about Black Friday.
qposner is offline
post #1196 of 2979 Old 11-19-2013, 12:27 PM
Cyrano's Avatar
Liked: 90
Are we within the price match period Amazon has for Black Friday?
Call Amazon and ask.
This a newer projector and the price seems pretty low. But at this time of year it is always a coin toss.
Last year at this time the Panasonic 220 3D player was $79. Now it is 2 to 3 times as much. I hesitated. I don't own one. Darn.
Cyrano is offline
post #1197 of 2979 Old 11-19-2013, 12:40 PM
Arqui3D's Avatar
Well, I guess patience is not my virtue... I pulled the trigger an hour ago and it's already on "Shipping now" status. :)
I live in Ecuador, so it will take a while for me to receive it, and I wanted to avoid the December congestion in mail services. I currently have a 5-year old Mitsubishi HC1500, so, this will be a nice upgrade.
Arqui3D is offline
post #1198 of 2979 Old 11-19-2013, 01:09 PM
Arqui3D's Avatar
Please... Could anyone be so kind as to post pictures of the cardboard box?
I need to know how to declare this projector in Customs. Does the box art present this as mainly a movie projector, or as mainly a data projector?
Arqui3D is offline
post #1199 of 2979 Old 11-19-2013, 04:13 PM
Legairre's Avatar
Quoted: 467 Post(s)
Liked: 269
I don't have one, but here's a video of one being unboxed. www.youtube.com/watch?v=D72KOr6f6CI
Arqui3D likes this.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Legairre is online now
post #1200 of 2979 Old 11-19-2013, 04:54 PM
Quoted: 89 Post(s)
Liked: 29
Just my opinion.
Ok that's somewhat of a relief then, cause boy i've had my share of faulty televisions and i do not want to add a faulty projector to it. It really isn't a big bother anyway, Certainly in no way as bad as it was on the Panny plasma.
By the way, currently i have the lamp mode set to bright, i like it quite a bit more than eco. The downside to this is that i will have less lamp hours if i choose bright, right? A whole lot less or not too bad? I also toned down the brilliant colour setting from 10 (max) to like 5. I noticed that colours looked far from natural at 10 and a whole lot more natural at 5, quite the difference.
Optoma Hd131xe Dlp Projector 3d
