Optoma HD131Xe, HD (1080p), 2500 ANSI Lumens, 3D-Home Theater Projector - Sub $800 New Budget King? - Page 76 - AVS Forum | Home Theater Discussions And Reviews
 36Likes
Old 02-12-2014, 02:58 PM
PM-Performance's Avatar
Quoted: 218 Post(s)
Liked: 139
I believe you need specific glasses compatible with this unit.
Not all glasses are universals. I wish they were as I have like 6 pairs if universal glasses alreasy
Klipsch RF-82|RC-62|RS-52|RB-51, 2 SI 18's in Marty Cabs Powered by Inuke 3000DSP|
Denon AVR-X4000|Oppo BDP-103|Epson 5020UB with Elite SableFrame 110"|
4 Aura Bass Shakers powered by Dayton PSA-250|4 Seatcraft 5131 seats
PM-Performance is offline
Old 02-12-2014, 03:35 PM
Moonwalker1982's Avatar
Quoted: 89 Post(s)
Liked: 29
There is one thing so far that i dislike about the HD131xe, no idea how this is with other projecters.
I mostply play videogames and sometimes watch movies or tv shows. The settings of the projector are very nice for my gaming now, but for movies it's just no good at all. When i watch a movie or tv show, faces of people are like they have been in the sun for waaaaaaaaay too long and it simply doesn't look too good. With tv's, in my case my previous plasma tv, i just had one preset for gaming and another one for movies/cinema.
The problem with the HD131xe is there seems to be only one 'user' preset. So let's say i choose the Cinema preset for movies, but i still don't like how the colours look, as soon as i change it, it becomes 'User' and all the settings i have for my gaming are now for movies too. There really is no way to have multiple custom presets? Each time i want to watch a movie now, i need to alter several settings for it to look decent....most of the time i end up changing nothing.
Moonwalker1982 is offline
Old 02-12-2014, 03:59 PM
Quoted: 218 Post(s)
Liked: 139
determine what means more to you. Natural "REAL" content. Or questionably nicer "fake" content? lol
I calibrated with a disc. I dont play many games, but even uncalibrated, the games I played looked good enough for me. I guess I dont expect games to look real is my problem?
Old 02-12-2014, 07:18 PM
Quoted: 89 Post(s)
Liked: 29
I used several gameplay videos from Youtube and other sites of the same game i was playing and from there i tweaked the settings on the projector to make it look similar to that. I just wish this projector would give me the option to at least have a second custom preset. Ah well, what are you gonna do right?
There were a few settings that made games look significantly better, but movies worse.
Old 02-13-2014, 10:43 AM
Cyrano's Avatar
Liked: 90
Yeah, the lack of multiple user settings is a bummer.
Finding a happy medium is your only choice. Maybe make it so that movies look good and then just pump up the unnatural contrast and color by putting Brilliant Color very, very high. Not too much menu manipulation that way.
Cyrano is offline
Old 02-13-2014, 11:07 AM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1702
Yeah, it's annoying. I had to set BC to 3 to get the 24hz and 60hz greyscales even close to each other. No idea why, but that's just how it is.
Steam/PSN/Xbox Live: Darius510
bd2003 is offline
Old 02-13-2014, 12:03 PM
8neo's Avatar
Hi guys. I've Just bought my optoma hd 131xe, everything is very good, but i'm wonder about one thing - in movies (1080 and 720) Xbox games and tv's i've got smth like "frame" around image. Is this normal ? [IMG].
8neo is offline
Old 02-13-2014, 12:10 PM
Quoted: 218 Post(s)
Liked: 139
It just means your image is not scaled to fit your screen. You will have to play with the zoom and focus settings manually and maybe internally within the settings if it bothers you.
I could never get mine %100, but its not as noticable anymore that I got it dialed in.
Old 02-13-2014, 12:47 PM
8neo's Avatar
8neo is offline
Old 02-13-2014, 06:00 PM
Beefcake's Avatar
I get this on the XBox360, but not my HTPC. I think the HDMI chip in the Xbox that does the scaling it to blame here.
Beefcake is offline
Old 02-13-2014, 06:27 PM
Cyrano's Avatar
Liked: 90
You might want to check in the menu settings. On the Display tab there are things to check.
Try Edge Mask and try Zoom and try Image Shift. Also make sure Keystone is at 0. (Unless you are using it to adjust for your offset correction.)
There is also a reset on the Options page (I think) that will reset the projector to the defaults. Someone might have made adjusts to your projector before you got it and they need removing.
You should not have that much large space of projected dark border around the lighted image area.
Good luck.
Cyrano is offline
Old 02-14-2014, 04:23 AM
Mikeclough24's Avatar
Quoted: 72 Post(s)
Liked: 29
So I just got my elite screen 120" set up tonight and just got done watching my first blu ray on it and damn. This thing is the **** for 720 plus the 300 for the screen. Pretty unbelievable. Thanks for all the help you guys gave me last week or so haha.
Mike Clough #24
Mikeclough24 is offline
Old 02-14-2014, 07:53 AM
Bengali's Avatar
I have mine few weeks now
Awesome video quality for the price
Only bummer is rainbow effect on black or dark scenes sci fi outer space movies
I got the expensive rf glasses
Didnt notice that much improvement in more light vs non rf glasses
There is no chance optoma will ever increase color wheel rate?
Thats the only down side for me
I have not register yet to send tech support email
Anyone want to ask if possible to increase color wheel rate through firmware
I know its a long shot
Just desperate to kill rainbows
Bengali is offline
Old 02-14-2014, 08:27 AM
stuart628's Avatar
Quoted: 44 Post(s)
Liked: 31
HA so the focus issue saga continues, I sent back my hd131xe that really wasnt as bad as the first one but it was still slightly there, and got a hd25e from amazon, this one has about a 1/4 of the screen out of focus and I mean out of focus, text is blurry in top right hand or bottom left hand corner depending on where I decide to zero in the focus....I called optoma and the woman said she has never heard of this at all...REALLY?! come on....Deciding wether to send it back to amazon or optoma....really do like what I see from the projector and trying to not be TOO picky as amazon is probably tired of the returns but there has to be a solution here...she said that it would be about two weeks before I would have a projector again.
stuart628 is offline
Old 02-14-2014, 10:28 AM
Quoted: 218 Post(s)
Liked: 139
Is it only text that you guys see this on?
Old 02-14-2014, 10:39 AM
stuart628's Avatar
Quoted: 44 Post(s)
Liked: 31
Its not just text, its pictures and video as well, if text is out of focus the picture will be as well...it wont be as razor sharp as it normall is, I could tell in a basketball game last night the crowd on the bottom was in focus where as the top left looked like a little haze was over them almost, just not as sharp. I think its enough where if you didnt notice text and werent looking for it most people would pass it by and not realize they have a problem.
Old 02-14-2014, 11:06 AM
Cyrano's Avatar
Liked: 90
To check out the focus issue use the menu positioning setting in the menu and try it out in ALL four corner positions. And open the zoom to the full wide position.
stuart628 likes this.
Cyrano is offline
Old 02-14-2014, 11:10 AM
stuart628's Avatar
Quoted: 44 Post(s)
Liked: 31
yep. I think this will show people if they have it or not. I was quoted a two week turn around by optoma to send this in for service. I was hoping for 3-4 days!
Old 02-14-2014, 11:15 AM
Cyrano's Avatar
Liked: 90
Ouch. I have to get mine in too. Darn.
I use the narrowest setting on the zoom so I don't see it. But if I ever go to the 120" screen that will fit in my HT I'll certainly see the problem. I currently have a 100" screen.
Cyrano is offline
Old 02-14-2014, 11:26 AM
stuart628's Avatar
Quoted: 44 Post(s)
Liked: 31
I dont want to scare anyone off from this projector, it really is a good one, I am sending the HD25e back to amazon and trying my luck with a brand new hd131xe (will be my third, again the second one had just a little tiny spot that had the out of focus, it really did have a nice picture!)
Old 02-14-2014, 01:43 PM
Quoted: 218 Post(s)
Liked: 139
Wonder if they are sending older units? Are you guys getting lense caps with your units?
Old 02-14-2014, 01:53 PM
stuart628's Avatar
Quoted: 44 Post(s)
Liked: 31
Second one had a cap and I noticed it was a shipment from optoma of like 24 where as the first was of 150 which leads me to believe it was newer to be honest I should have kept that one instead of getting hd25e used just thought I could squeeze extra lumens out and get lucky on focus issue
Old 02-14-2014, 03:08 PM
MJA28's Avatar
No lens cap and I bought mine last week
Sent from my Nexus 5 using Tapatalk
MJA28 is offline
Old 02-14-2014, 03:13 PM
Redogfizbal's Avatar
Did you get it on amazon?
Redogfizbal is offline
Old 02-14-2014, 03:17 PM
MJA28's Avatar
Yes
MJA28 is offline
Old 02-14-2014, 03:22 PM
Message them and ask for one or a discount. I got mine a few weeks ago, and it came with a lens cap. Also google "optoma hd 131xe amazon promo" copy the link and ask for the 50 dollar amazon credit. It worked for me.
Good luck
Old 02-14-2014, 04:10 PM
Quoted: 72 Post(s)
Liked: 29
What does the lens cap do? Just keeps it clean? Do you leave it on all the time or just when you arent using it? And can I just order one?
Mike Clough #24
Old 02-14-2014, 04:25 PM
MJA28's Avatar
I have 2 kids age 4 and 5 and they like to TOUCH every thing with their greasy peanut butter fingers lol .
MJA28 is offline
Old 02-14-2014, 04:27 PM
MJA28's Avatar
I just sent them an email I hope it works.$50 will go toward the " Screen saving fund" smile.gif
MJA28 is offline
Old 02-14-2014, 05:34 PM
Hien27's Avatar
Hi all,
I'm new here and this is my first post. Just wanted to throw in my 2 cents about the HD131xe. I love it and it has exceeded my expectations. I have this on Carl's ProGray screen cut to be 130" and this is me playing PS4 BF4 on it. My camera phone doesn't do it justice but it is quite bright and vibrant even with partial ambient light.
Hien27 is offline
Optoma Hd131xe Dlp Projector 3d
