Optoma HD131Xe, HD (1080p), 2500 ANSI Lumens, 3D-Home Theater Projector - Sub $800 New Budget King? - Page 93 - AVS Forum | Home Theater Discussions And Reviews
 36Likes
post #2761 of 2979 Old 07-18-2014, 01:19 AM
Nicktx27's Avatar
Quoted: 64 Post(s)
Originally Posted by Nateuofmn View Post
What distance from screen should this be at to get the best picture quality on a 100" screen? The defaulted zoom on Optoma's sight shows 11' 11" I think. Can someone tell me of this is at no zoom?
Go to www.projectorcentral.com and click the calculator.
That will give you everything you need for throw distance, zoom, offset, ect..
Nicktx27 is offline
post #2762 of 2979 Old 07-18-2014, 05:04 AM
Quoted: 13 Post(s)
Liked: 0
I've been on there and it says 11'11" at 1.10 zoom. Is 1.0 at no zoom? Do you think 1.10 zoom affects image quality?
Nateuofmn is offline
post #2763 of 2979 Old 07-18-2014, 01:18 PM
Blindman0v0's Avatar
Quoted: 42 Post(s)
Ok. I'm mounting it today I think and if I'm off a few inches can I make it a little bigger or smaller? My 100" screen will be here Monday, but if like to at least get the projector up. Thanks.
My measurement was with no zoom at 12' from the screen. So if you mount it at about 11" that will put you in about the center of your zoom capability. Any time you zoom you're going to degrade the picture a little. Doesn't matter whether its digital or analog. But having said that even zoomed the picture is still pretty darn good.
Blindman0v0 is offline
post #2764 of 2979 Old 07-18-2014, 02:31 PM
Nicktx27's Avatar
Quoted: 64 Post(s)
I'm pretty sure 1.0 is no zoom. I know on some projectors zooming out can increase the chance of seeing SDE, but I believe if you buy a decent screen this mitigates some of those issues. I don't think the 131 has that issue.
Anyone can correct me if I'm wrong.
Nicktx27 is offline
post #2765 of 2979 Old 07-18-2014, 08:06 PM
Quoted: 13 Post(s)
Liked: 0
Thanks for all the help. Projector is up, man those 3mm screws suck. Not too many stores have them. My 25' hdmi cord is too short, so I have to return it for longer tomorrow. Hope the quality doesn't suffer.
post #2766 of 2979 Old 07-19-2014, 10:29 AM
Quoted: 42 Post(s)
The only flaw I've found in this projector is the weak signal strength detection and you might have a problem with that. I have a 25" HDMI 1.4 cable and the projector will lose signal from the blu ray player while changing between different files. Have never had it lose detection during any file or blu ray playing though, so its just a bit of a nuisance.
post #2767 of 2979 Old 07-19-2014, 01:11 PM
Quoted: 13 Post(s)
Liked: 0
What do you mean by files? Menus?
post #2768 of 2979 Old 07-19-2014, 09:37 PM
Quoted: 13 Post(s)
Liked: 0
So I have everything hooked up and it doesn't work with my 25' hdmi cord, hdmi extender, and 6' hdmi on the other end. I know, too many things. So I moved my bluray player next to the projector and everything works perfect with a 6' cord. I'll try hooking it up just to the 25' and see if that works tomorrow. Otherwise, Iron Man 3 looks great with it all right out of the box projecting on my wall.
post #2769 of 2979 Old 07-20-2014, 06:00 AM
Quoted: 13 Post(s)
Liked: 0
It's the 25' HDMI cable. I've read that some cables are directional, but I really don't want to take this out of the ceiling and run it the other way.
post #2770 of 2979 Old 07-20-2014, 10:26 AM
Quoted: 42 Post(s)
Movies video files. I play a lot of mkv files. I know the mindless idiots in the movie business hate people like me but they shouldn't. I will download a movie and watch it and if I really like it I go purchase the blu ray. They never think about the positive aspect of file sharing. Just the greed. I wouldn't buy any blu rays if I couldn't see if the movie is any good first.
post #2771 of 2979 Old 07-20-2014, 10:29 AM
Quoted: 42 Post(s)
Was it a 1.4 cable? Might have to buy an updated cable for your length. Never a good idea to patch cables together. I've considered buying one of the hdmi signal boosters but haven't yet.
post #2772 of 2979 Old 07-20-2014, 10:50 AM
Quoted: 13 Post(s)
Liked: 0
I just tried doing the 25' alone and that didn't even work. I went and bought the 50' and that does work, weird. All up and running now.
post #2773 of 2979 Old 07-23-2014, 03:12 PM
Liked: 0
Lightbulb 120hz native input?
Hey folks,
I'm new to the world of projectors, and I'd like to ask if anyone with this unit has been able to successfully get a 120hz 2D input at 1080p to work correctly? I want a projector with these specs for movies and for high-framerate gaming from a PC, so 120hz input at 1080p is ideal. There are a lot of 3D TV's out there that support that setting, but none advertise it, and it takes a lot of research to find that information out. It has proven even more difficult on projectors!
Thanks in advance!
MrPeter is offline
post #2774 of 2979 Old 07-24-2014, 11:24 AM
Quoted: 42 Post(s)
Originally Posted by MrPeter View Post
Hey folks,
Thanks in advance!
Under the specs is does say Vertical Scan Rate 24–85Hz, 120Hz, 144Hz. Haven't messed with it though myself.
post #2775 of 2979 Old 07-24-2014, 11:25 AM
Quoted: 42 Post(s)
Must have been a bad cable. You have any issues witht he projector losing connection while changing files? The dreaded old hourglass pic
post #2776 of 2979 Old 07-24-2014, 12:11 PM
Liked: 0
Well, for something to support 3D in 120Hz, it MUST support 120fps input, so that's pretty much a given. For some reason that is technically beyond me, a lot of TV's (and I am thinking projectors too) do not advertise support for inputting a standard 1080p 2D signal at 120Hz, even though they can support it. As a result, when connecting to a computer, the option to up the output Hz setting is not available.
There are workarounds of course, to force the output to 1080p at 120Hz in 2D mode, but many display devices don't play nice with this setting for some reason. There are threads on here about which TV's do support it, but not one for projectors.
And before anybody asks, 120Hz in 2D is superior for high-fps gaming when compared to 60Hz. It looks better, and feels much more responsive. That's why I'm hoping for it.
MrPeter is offline
post #2777 of 2979 Old 07-24-2014, 12:21 PM
Quoted: 13 Post(s)
Liked: 0
Yes I get the hour glass. I'd say it's a 3-5 second delay. Once the disc is loaded all is well.
post #2778 of 2979 Old 07-25-2014, 10:11 AM
Quoted: 42 Post(s)
Same with mine. Wish they would come up with a fix. Thought about buying a signal booster to amp the signal up a little.
post #2779 of 2979 Old 07-28-2014, 09:15 AM
Liked: 0
Hi all,
I have a weird one here. Just bought one of these off the Optoma ebay outlet store - thought I'd ask here while waiting for their reply - the unit itself seems to work, but the remote is very weird - pressing 'Native' actually does Volume Up, 'Contrast' does Volume Down. Other buttons do nothing or at least not what they are meant to.
The remote is model number L-27-5KEY - is that correct? It looks right from pictures I've seen online.
Cheers,
Steve
SteveC00ps is offline
post #2780 of 2979 Old 07-28-2014, 11:18 AM
Quoted: 42 Post(s)
Thats the same remote I have. Must be bad. Send it back to Optoma and get a replacement.
post #2781 of 2979 Old 07-30-2014, 12:41 AM
Liked: 0
They came back to me straight away saying I probably have been given an HD131x remote by mistake as they look identical but don't work on the HD131xe and has put one in the post for me. I'll see what it's like when it turns up.
post #2782 of 2979 Old 07-31-2014, 11:51 AM
GammaBreaker's Avatar
24 Hz VS 23.976 Hz
Received mine, and am overall happy with it. In the PC's display mode options, it lists both 24 Hz and 23 Hz. The latter is usually the OS's shorthand for 23.976, and it does appear to accept it as a mode.
That said, when playing back 23.976 FPS videos in either mode, there is some pretty severe tearing. This leads me to believe that there is in fact not a true 23.976 mode within the Optoma, and that it's simply going back to 24 FPS. ReClock is able to bludgeon the playback into a mostly tear-free state, but I just wanted to make sure that I wasn't missing something, and if I could attain true 23.976. On my Panasonic LCD TV, it took some fidgeting on the PC end before it would finally cooperate with the TV to do such.
GammaBreaker is offline
post #2783 of 2979 Old 08-01-2014, 10:00 AM
Quoted: 42 Post(s)
Haven't had any problems with playback of video files through my Samsung blu ray player into the projector. Its just dependant on the quality of the video files and the player being able to play them.
post #2784 of 2979 Old 08-05-2014, 02:10 PM
Lt_Sully's Avatar
Per the manual, the HD131xe has TWO IR receivers. One in the front by the LENS and the other on the top near the CONTROL PANEL. My brand-new unit will only respond to IR commands in the front. The control panel IR receiver is not working. So I opened up a TROUBLE TICKET with Optoma and they RMA'd it. I sent it in...wait 3 weeks now and they are saying they found NO TROUBLE. They are telling me that it only has ONE IR RECEIVER in the front. So it is operating correctly.
Can someone please CONFIRM QUICKLY this information. Does your HD131xe respond to remote control IR commands if pointed directly at the TOP control panel? You have to be sure you are not getting reflected IR. My unit was mounted upside-down on the ceiling. If I pointed the remote directly at the unit it would NOT respond. I had to walk into the front of my theater, hold my hand up in the air and point it at the front of the unit.
Thanks for your QUICK response!
Sully
Lt_Sully is offline
post #2785 of 2979 Old 08-06-2014, 05:50 AM
vj950's Avatar
There is only one receiver, next to lens
vj950 is offline
post #2786 of 2979 Old 08-06-2014, 01:26 PM
Quoted: 42 Post(s)
Yep, just the sensor next to the lens. Seems to operate at a pretty good angle because mine is sitting next to me on the coffee table and all I have to do is hold the remote to the right and slightly in front of the projector and the remote works fine.
post #2787 of 2979 Old 08-06-2014, 01:31 PM
russellhk's Avatar
That's not strictly true, as the mandatory HDMI frame packing standards do not take a 120hz input but they do (with active 3d) use a 120hz (or 144hz) output.
Most 3d projectors will take a 120hz input but not at all resolutions. Depends on what your source is too, as the EDID of the display device will advertise what input resolutions are supported but sometimes you can override it and see what inputs a device is actually capable of taking.
russellhk is offline
post #2788 of 2979 Old 08-07-2014, 08:15 AM
madrid64's Avatar
Hi everybody, I finally pulled the trigger on this projector, I'm coming from a vivitek qumi q2, I've heard many great things about this optoma, I hope that it delivers and I expect the jump to be quite evident, right?? my screen is 110', so the waiting is going to feel like an eternity lol ( I was going to buy the benq w1070 but the throw it has was too short and moving the ceiling mount was a no go from the wife lol, but I'm happy with my purchased and I'm sure I wont regret.
madrid64 is offline
post #2789 of 2979 Old 08-07-2014, 11:11 AM
Quoted: 42 Post(s)
The majority of us have been pretty happy with the projector especially at this price point. Would be nice if they would fix the losing signal while changing files problem and I wish the focus wasn't quite so touchy but I love the quality of the picture it produces.
lgans316 likes this.
post #2790 of 2979 Old 08-07-2014, 07:33 PM
thediscexchange's Avatar
Having an issue with 3d signal. It loses signal then just goes fuzzy (snowy) while watching a 3d bluray on my ps3 (latest firmware). I'm using premium hdmi cables into a yamaha 675 receiver (latest firmware) then out to the projector. I can change the input on the amp to my hdtv box and back to the ps3 and it corrects itself. But I hardly think I'm gonna be happy about doing that every time.
thediscexchange is offline
Optoma Hd131xe Dlp Projector 3d
