Optoma HD25 or HD25e - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-23-2013, 05:31 AM - Thread Starter
Dres1's Avatar
Hello,
I am building my first home theater and have a dilemma. I will be projecting from 14' onto a 120" diagonal screen in my finished basement. There is a tini window in the corner which I can completely black out, so I have great light control. I kind of want to get the HD25e because I read that it is more efficient and has a cheaper replacement bulb, but my fear is that it is going to be too bright for my application. Can you guys comment on whether you think it is too bright for a dark basement? can I just turn down the brightness on the projector without sacrificing image quality?
Additional quesions: I know the digital keystone adjustment degrades image quality, but is the degredation proportional to the angle? in other words, if I just have to tilt the projector a little bit, will I sacrifice less that if I have to tilt it dramatically, or is it an all or nothing thing? I'm asking because I have a fairly low ceiling (87"). On a related note, can anyone recommend a very low profile ceiling mount that would be compatible with the hd25e? Thanks for your time guys, and please forgive my ignorance as this is my first go round.
Dres1 is offline
post #2 of 4 Old 08-23-2013, 07:18 AM
terry2's Avatar
Quoted: 33 Post(s)
Liked: 25
Originally Posted by Dres1 View Post
Hello,
Mine is in a basement room with dark walls and ceiling. I run it in Eco mode and the brightness is just right so don't think you will have an issue with brightness. My ceiling is also low but a little higher than yours (92") but it's not a problem. I use the Mustang mount but you may need one with a little less drop. Amazon has mounts with only a couple of inch drop. A little tilt won't be noticeable with 16:9 material but if you tilt it too much you will see a bow in the image when watching scope material.
terry2 is offline
post #3 of 4 Old 08-23-2013, 08:12 AM
gwlaw99's Avatar
There is no reason to get the HD25 anymore. The Optoma HD131xe is the same but much cheaper and a little brighter.
gwlaw99 is offline
post #4 of 4 Old 08-23-2013, 01:35 PM
coderguy's Avatar
Quoted: 322 Post(s)
Liked: 277
With a lower wattage lamp producing slightly more lumens, I would surmise that the on/off contrast of the Optoma HD131xe would be lower than the HD-25. Since the brightness and light path has been changed, I would not say this is exactly the same projector. Need to find some reviews to see if it took a black level hit.
Access HERE from this thread
coderguy is online now
Optoma Hd25e 2800 Ansi Lumens 3d Home Theater Projector
