The Offical Epson 2030 2D/3D 1080p 3LCD Projector Thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 37Likes
post #271 of 625 Old 04-25-2014, 06:34 AM
NoVaT's Avatar
I have not noticed any curve to the bottom of my picture. In my experience the deposit, or sometimes just a hold on a card, is pretty standard if they are going to front you the product so you are not without a projector for the exchange period.
BDUB619 likes this.
NoVaT is offline
post #272 of 625 Old 04-25-2014, 10:49 AM
Dodgedriver67's Avatar
 Do you have yours ceiling mounted? If so how far from the ceiling and screen is it mounted?
The screenshots on projectorreviews dot com show the same pincushion or curve except theirs shows at the top of the screen since they had theirs set on a table.
 This is the first time I've been asked for a specific dollar amount for a hold. I've advance exchanged things before and was just asked for a valid card to use but wasn't charged or had any authorization hold placed. Directv just sent me a new genie as an advance exchange  with no credit card hold needed. My biggest gripe is how rude the tech reps are there. The one guy immediately got an attitude cause he claimed he couldn't hear me well enough.
Dodgedriver67 is offline
post #273 of 625 Old 04-26-2014, 08:55 AM
NoVaT's Avatar
7'7" floor to ceiling in my basement. Ceiling mount 13" from ceiling to top of projector (or bottom I guess since it is upside down). From 106" screen to front of the lens is a little less than 10 ft. I looked at it pretty hard and I don't see the distortion, that is pretty obvious in your pictures, on the top or the bottom.
I see from a previous post you have a 106" screen and your projector is about a foot further away. I wonder if the curve may have something to do with the amount of zoom used. You image would be larger at the same zoom setting with the projector further away. That would require you to shrink the image with the zoom ring, right? Maybe that adjustment is causing the bow.
I will try to zoom mine to a smaller image and see if I can see any bowing.
NoVaT is offline
post #274 of 625 Old 04-26-2014, 09:24 PM
NoVaT's Avatar
Still don't see any curve to the picture. I even put a yardstick up and had my wife stand back and see if she could see anything and she is pretty picky.
NoVaT is offline
post #275 of 625 Old 04-27-2014, 10:28 AM
 Thanks for checking. I think I'll take a shot at having Epson swap it out. I'll probably send it in since I can do without the PJ for a couple of weeks.
post #276 of 625 Old 04-27-2014, 06:19 PM
NoVaT's Avatar
Good luck. I think it's worth a shot. You can always return it if the second one doesn't work out.
NoVaT is offline
post #277 of 625 Old 04-30-2014, 10:57 AM
tobisama's Avatar
A quick question for everyone with this projector. It's normal that after a while the fan noise increases?
I have mine ceiling mounted, and I sit under it. Always in eco mode, after about 20 or 30 minutes of use the fan noise increases, I mean the sound is not constant, I did the test with high altitude mode on and off (because I live in a high city), and there is no difference, the fan speed (and noise) increases after a while.
tobisama is offline
post #278 of 625 Old 04-30-2014, 11:04 AM
IVB
IVB's Avatar
I'm not guaranteeing that mine doesn't do that, but I certainly haven't noticed it. And I always use Eco mode.
Sent from my Nexus 5 using Tapatalk
Yes, I'm "that" Home Automation Guy.
IVB is offline
post #279 of 625 Old 04-30-2014, 03:52 PM
 I haven't noticed the fan getting louder after being on for a while. It is quite loud when I first turn the thing on. Once it warms up and I get some content on the screen it quiets down a lot. I have mine in eco mode cinema. Watched a Ron White stand up special which is mostly talk and didn't notice the fan.
 If the fan is getting louder as you go I would think the PJ is heating up and the PJ runs the fan harder to cool it down. Maybe check your dust filter.
 Seems like problems on this model PJ are hit or miss. Some folks have no problems and others have different problems.
post #280 of 625 Old 05-07-2014, 04:27 PM
BDUB619's Avatar
Quoted: 328 Post(s)
Liked: 219
Mine remains about the same noise level. Sounds like your bulb is overheating (either warm room or dust?). Makes sense that the fan speeds up, hence the noise, after about 20 minutes because by then the bulb has warmed up. I wonder if it really is the altitude? Interesting.
Speaking of fan noise, I notice mine is a little louder at first start up but then after about 2-3 minutes, it's fairly quiet. During viewing, it depends on what I'm watching. I was watching NBA playoffs the other night and suddenly realized I heard NO FAN NOISE. I even got right under the PJ to listen for it and couldn't hear it (yep, the fan was still on). Guess it just depends on the temperature in the room, temp of the bulb and what's being displayed on screen....and altitude.
Sony HW40es Projector / 106" Silver Ticket screen
Sony 70" W830B LED TV
Xbox One GT: JonnyRingo619
PS4 GT: Ringo619
BDUB619 is offline
post #281 of 625 Old 05-09-2014, 10:16 AM
zich's Avatar
Has anyone had their 2030 lamp refuse to come on? Mine started doing this last night. Eventually, the orange lamp error light comes on. I can't imagine the lamp burned out... it probably has maybe 50 hours on it.
zich is offline
post #282 of 625 Old 05-19-2014, 11:12 AM
BDUB619's Avatar
Quoted: 328 Post(s)
Liked: 219
Not a common error. Have you checked with Epson?
I have ~350 hours on my lamp and haven't had any issues so far.
PS4 GT: Ringo619
BDUB619 is offline
post #283 of 625 Old 05-19-2014, 08:23 PM
zich's Avatar
My lamp burned out. At 47 hours. Epson sent me a new lamp. Hopefully it's not indicative of a larger issue.
zich is offline
post #284 of 625 Old 05-24-2014, 11:05 AM
bigfinn's Avatar
Hi all,
I'm a newcomer to home PJ and have been looking through this thread for the past couple hours. My question, is there any noticeable difference between the 2030 and 2000 when it comes to input lag, brightness, or picture quality?
I am a gamer and am looking for no noticeable input lag, with a bright screen for gaming during the day (my room has curtains that allow some ambient light) but am easygoing with regards to the finer points of image quality. Thanks!
bigfinn is offline
post #285 of 625 Old 05-24-2014, 02:49 PM
bigfinn's Avatar
How is the 3D with this PJ at a 140" screen? Is it bright enough?
bigfinn is offline
post #286 of 625 Old 05-27-2014, 10:58 AM
I just bought this projector Sunday (replaced a 9 year Ingocus SP4805) Showed The Lego Movie outside for my nephews. Love it! Now I need to buy some KIDS 3D glasses. Anyone know where I can find some? .
GraceAdler is offline
post #287 of 625 Old 05-29-2014, 09:56 AM
BDUB619's Avatar
Quoted: 328 Post(s)
Liked: 219
Amazon.com
3D Active Glasses - Samsung SSG-5100GB
I think they're still under $20/each. I bought 2 of them and they work great...and 4x less $$ than the Epson 3D glasses.
PS4 GT: Ringo619
BDUB619 is offline
post #288 of 625 Old 06-10-2014, 11:04 AM
obonillaf's Avatar
Quoted: 62 Post(s)
Hello. I have a 5030 projector and as I am loving the "projector experience" a new interest of watching everything on a big screen has grown to me so I am looking for a cheaper projector to use it on a daily basis (about 2 hours per day) and the 5030 for movie watching on the weekends.
I use my 5030 on a shelf that that if I were to draw an imaginary line from the lens projector to the screen said imaginary line would be just 8 inches shy from the center of the screen (my screen is a 135" with a total height, incluiding frame, of 70 inches). Horizontal wise the projector would be also about 8-10 inches from the center. The shelf is about 14-15 foot from the screen and placing the projecto in said shelf will make the projector to be about 4.4 feet from the ground.
I can center the image with the 5030 using it's lens shiffting features with no problem at all.
My question is: Even though the 2030 has no lens shiftting can I place it in the shelf where I place the 5030 and manage to adjust the image (vertically and horizontally) using keystone or other methods? I have read that projectors without lens shiffting can only be placed either high on the ceiling or in a low coffee table but no at the middle of the road (almost the same distance from the floor than to the ceiling) but would like to know if the 2030 would allow my shelf positioning.
Thank you!!
obonillaf is offline
post #289 of 625 Old 06-10-2014, 08:06 PM
NoVaT's Avatar
Originally Posted by bigfinn View Post
Hi all,
I can't speak to the 2000, but I have the 2030. I am not a "hard core gamer" by any means, but I do a fair amount of gaming with an Xbox One on the 2030. There are 2 settings for the image processing, "fast" and "fine". For me there is noticeable lag when you have this projector set to "fine" mode. It is noticeable, to me, in Forza even playing single player. The car just feels sluggish and it is difficult to do well. I cannot feel the lag when it is set to "fast". I don't seem to be doing any worse in online-multiplayer matches on COD in "fast" mode. I didn't even try online play in "fine".
As long as you have a good signal coming in "fast" mode does not look much different than "fine". If I am watching a movie or trying to show off the projector I do try to remember to switch it over to "fine" because it does make a slight improvement in the picture. Picture quality on this thing is amazing with Blurays.
I don't have any windows in the room where I have the 2030. The kids do come down there to play and turn lights on and I don't find it difficult to see. It definitely suffers more from ambient light than a flat screen would.
NoVaT is offline
post #290 of 625 Old 06-17-2014, 07:58 AM
steve1106's Avatar
Quoted: 533 Post(s)
Liked: 297
I have the Epson HC2000 (cheaper/less bright sister of the 2030) and it currently has a little over 1200 on the lamp/filter at eco mode with no issues. We got it in November and it functions as a TV (with a 169 inch 16:9 image on a painted wall) with an average daily use of about 5 hours. I did recently bump up the brightness via the remote from the factory setting up 1.
As far as gaming, South Park Stick of Truth is all we have played on it so I can't speak to lag issues.
As to noise issues, the projector is mounted directly above our seating position and we do not notice the fan noise. It is in the basement so the temperature averages 68 to 73 in both the winter and summer. (We like it cool.)
As to mounting, I have it mostly right after several attempts...but, I don't have it perfect (centered) so the image drops/slopes a little to the right. I can't say that we really notice the slope unless we are looking for it.
We watched the Lego movie on blu-ray last night and the slope might be a little more noticeable on a non-16:9 image.
As to 3d, my family/3 girls are not fans of 3d, so I will watch the 3d version of the Lego movie this weekend by myself which is how I watch all 3d content. Six pairs of glasses and I am the only one (except for the occassional friend) who enjoyes 3d. Good 3d on the projector is once I move my seating position from about 14 to 16 feet up to 10 to 12.
As a person who went to the movies almost every weekend, I haven't been to a theater since I got the projectors (my girls have been to a few). Sometimes it is hard to wait, but worth it. Family of four to one movie plus snacks and if we have to see 3d due to a sold out 2d, we really save. The projector has paid for itself in six months. Now if the projector lasts another 6 months that covers the 5.2 surround and if it lasts another year, that takes care of the two new theater seats. (One 7 day vacation to Florida/Disney/beach we spent about $350 at theaters due to weather and getting stuck with several 3d movies as the 2d sold out. A projector and Amazon Prime will now travel with us for all beach/park vacations.)
So to sum up, I have been very pleased with the Epson...but I also have a Viewsonic with a SVGA image and I am equally pleased with it (600 hours since September), so I am probably not the best judge of image quality since I prefer both projectors (Epson - 169 inch image on a wall, Viewsonic - 92 inch image on a screen) to my Sharp 70 inch TV.
steve1106 is offline
post #291 of 625 Old 06-19-2014, 04:30 PM
BDUB619's Avatar
Quoted: 328 Post(s)
Liked: 219
Hi all,
I have the 2000 and I use it mostly for games and movies and more games. Brightness is not an issue at all as this thing is a real light cannon, I never even take mine out of Eco mode. PQ is excellent, as good as an LED IMO (blacks aren't the inky black but at this price point, they're excellent). LAG: When I play offline, I keep the PJ in FINE mode for better detail. But if you play online, definitely keep it in FAST mode, I believe that keeps it ~30ms lag time, very good / acceptable. FAST mode cuts down on some of the detail on screen but you'll only notice if you sit right up next to it. FAST mode is the only way to go if you play FPS online.
PS4 GT: Ringo619
BDUB619 is offline
post #292 of 625 Old 07-03-2014, 08:30 PM
perpetual98's Avatar
Quoted: 69 Post(s)
Liked: 46
I just ordered this projector and I'm stoked for it to get here. It's on backorder now from where I ordered it, but I have some work to do in that room anyway, so no big deal. Right now I have an ancient 1024x768 projector that I picked up from a local community college for $75 and the kids get a kick out of the 120" screen in the basement, but I'm always irritated at the resolution and screen-door-effect.
perpetual98 is offline
post #293 of 625 Old 07-04-2014, 12:13 AM
b15nut's Avatar
How does ambient light effect your picture? I am looking at the calc and a 106" image from 10'6" shows 31fl. Anyone viewing this in a non light controlled room during daylight hours that can post a pic for us? Thanks.
b15nut is offline
post #294 of 625 Old 07-17-2014, 09:57 PM
Quoted: 69 Post(s)
Liked: 46
Just got the projector today via FedEx. Played with it a little bit and was blown away by the picture improvement over my old 1024x768 projector. After I played with it I mounted it to my ceiling mount, but it's about 6 feet too far from my screen so the image is gigantic. I think I need to order another down-tube for my current ceiling mount, so hopefully I can get everything dialed in next week. I really had no interest in 3D prior to ordering the PJ, and I didn't order it for 3D, but now I'm kinda itching to try it out, so I will probably order a couple pairs of those Samsung glasses off of Amazon.
BDUB619 likes this.
post #295 of 625 Old 07-17-2014, 10:00 PM
joe221's Avatar
Quoted: 29 Post(s)
You are gonna go crazy! I highly recommend Avatar and Hugo. The 3D is amazing in both.
Joe in West Los Angeles, CA
joe221 is offline
post #296 of 625 Old 07-17-2014, 10:07 PM
Quoted: 69 Post(s)
Liked: 46
Oh yeah, I will for sure check out Avatar. Terrible movie as far as plots go, but I've seen it a million times because of the effects. Do they have an extended version in 3d? I will probably check out (if available) Monsters vs. Aliens, Megamind, Tangled, etc. Can you tell I have little kids?
post #297 of 625 Old 07-18-2014, 08:19 AM
joe221's Avatar
Quoted: 29 Post(s)
I love animation too, and I'm old (LOL). (Film school ) I just got Ice Age Continental Drift for the great reviews and $10 on Amazon by third parties. There's a fourth disk with a 3D Christmas story in the package and I couldn't find it listed??
Also: I got Hugo for $12, watch for a sale and grab it too! You will not be sorry.
joe221 is offline
post #298 of 625 Old 07-18-2014, 02:37 PM
BDUB619's Avatar
Quoted: 328 Post(s)
Liked: 219
I'd highly recommend "Gravity" also. Amazing 3D. I also enjoyed Promethius, Life of Pi, and even Top Gun in 3D, amazing dogfights.
I notice most 3D movies don't really pop out of the screen at you, more that they just give you depth in the picture. Anyone else notice this? There were a couple scenes in Gravity and Pi where things come out at you and those were really cool.
PS4 GT: Ringo619
BDUB619 is offline
post #299 of 625 Old 07-18-2014, 03:17 PM
joe221's Avatar
Quoted: 29 Post(s)
Extension is used sparingly in good movies. Too much poking in the eye will turn off audiences. In Hugo the Inspectors leg and the Moon were notable scenes that broke the plane and extended. To enhance the effect, reach for it. Bringing your hands to meet the object makes it more fun too. I'm building my 3D collection I do have Gravity and Promethius but haven't run them yet. I don't have my 2030 permenantly mounted, I bring it out and set up a screen. After experiencing this projector I am sorry I didn't get a 3D TV when I bought my Sharp last year. Live and learn.
joe221 is offline
post #300 of 625 Old 07-18-2014, 03:59 PM
BDUB619's Avatar
Quoted: 328 Post(s)
Liked: 219
Yeah, definitely not complaining about the depth of 3D. Really helps with the immersion. I move the sofa closer to the screen, so about 7-8' away, the screen takes up the whole field of vision during 3D movies. Totally addicted to the 3D now and adding to my collection of movies also. FWIW, I have a 70" Sony LED in the living room that's active 3D and I never use the 3D on it lol. If I'm going to watch 3D, it's on this PJ in the theater room
PS4 GT: Ringo619
BDUB619 is offline
Epson Powerlite Home Cinema 2030 3lcd Projector , 3lcd Projector 2200 Lumens
