The Offical Epson 2030 2D/3D 1080p 3LCD Projector Thread - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 37Likes
post #331 of 627 Old 08-04-2014, 11:37 PM
ALtlOff's Avatar
Quoted: 1185 Post(s)
Liked: 594
Ok, I'm officially impressed, since this is my first projector I've got nothing to compare to but over the weekend I decided to get the projector up and running, needed to build a new component stand for my receiver and center, and since my xbr has a bad blue color block (been living with it for way too long because of a 3-4 week repair time) I decided to go ahead and fire the projector up for the first time to start calculating distances and mounting position, and I gotta say this thing really surprised me, even on my tan colored, textured wall it looks fantastic.
Can't wait to actually do it right, and looks like I'm going to end up at 171" for the screen wall, but I'm totally impressed for under $900.
I'm going to start a build thread, there's lots of work ahead, might as well chronicle it.
Build thread:
http://www.avsforum.com/forum/15-general-home-theater-media-game-rooms/1630473-fam-glam-my-family-room-transformation.html#post26303057
joe221 and BDUB619 like this.
ALtlOff is offline
post #332 of 627 Old 08-12-2014, 01:38 AM
bladecutter_ph's Avatar
Selection for Aspect mode is set to Normal. The rest namely, Full and Zoom, are in grey shade and cannot be selected.
Any reason why the Aspect mode is fixed at Normal? How do you change Aspect mode?
Second, the settings from the Configuration menu (image, advanced RGBCMY)are in zero. Any suggestions of a good configuration? It's difficult to experiment the settings. Maybe someone could share a good configuration for movies.
Thanks in advance for any help.
bladecutter_ph is offline
post #333 of 627 Old 08-12-2014, 04:17 PM
NoVaT's Avatar
I shared all my settings on page 11 of this thread. Of course depending on your room setup these may not work for you. Looks great in my dark basement.
Are you using HDMI input? If so, the aspect mode setting is not available.
NoVaT is offline
post #334 of 627 Old 08-12-2014, 06:07 PM
Unhappy
Thanks for sharing the settings, already tried it.
I'm using HDMI as input, but the aspect mode is still fixed at Normal.
post #335 of 627 Old 08-13-2014, 06:37 AM
NoVaT's Avatar
Epson's online manual for the projector describes that setting as:
"Sets the aspect ratio (width-to-height ratio) of the selected source; not available for HDMI sources".
It will be fixed at normal unless you use a different input.
Here's a link to the manual:
Epson 2000/2030 Manual
NoVaT is offline
post #336 of 627 Old 08-13-2014, 07:18 AM
DanHorse's Avatar
Quoted: 28 Post(s)
Guys, I am pondering getting this PJ and am interested in those who have used a grey surface with this it - have you obtained decent results? My own room is light controlled but not a bat cave and I think I might need to go grey screen to get a nice deeper PQ.
Been giving some thought to screen material too, in my view a vinyl/PVC type material would be best as the surface is super smooth (there is a company selling PVC grey screen material here in the UK).. thoughts?
Best,
Dan
DanHorse is offline
post #337 of 627 Old 08-13-2014, 09:49 AM
Liked: 2
I tested some samples from carada. The grey looks really good wih dark movies like starwars or the dark night. But skin tones seemed off to me on most other movies. If you watch alot of kid/family movies I don t think its right. I was ready to pull the trigger on grey srceen sfter seeing the dark night. But now im leaning towards classic cinema white. Contact some of the screen makers and request samples. Then you get to decide what you like best
CostlyBurrito is offline
post #338 of 627 Old 08-13-2014, 10:30 AM
DanHorse's Avatar
Quoted: 28 Post(s)
Yes that was my first thought when i used a grey screen early on with my HD65.. its a balancing act of compromises I guess.
Best,
Dan
DanHorse is offline
post #339 of 627 Old 08-14-2014, 09:10 AM
TyTimp's Avatar
I tested grey when trying to pick out a screen. For me, the grey screen hurt the whites more than it helped the blacks.
TyTimp is offline
post #340 of 627 Old 08-17-2014, 11:01 AM
Soul_Reaper_SKN's Avatar
Liked: 0
http://www.projectorreviews.com/epso...image-quality/
http://www.projectorreviews.com/opto...-image-quality
Almost finished with my home theatre room and ready to buy the projector . Why is the James Bond pictures so yellow compared to the optoma hd25
Soul_Reaper_SKN is offline
post #341 of 627 Old 08-25-2014, 12:23 AM
Liked: 0
Hi
New user here as I've just bought the TW5200 which I believe is the same as the 2030
Set it up on Saturday after picking it up from the shop and just testing out on the blue grey wall I have, I must admit I am happy with the choice of PJ so far
It did have some keystone adjustment and with the wall, the image was a little soft but hoping to get the screen soon which should help with that plus a proper install.
One thing that I need to confirm... I noticed the fan seems extremely loud... Like those old PC case fan on high speed...with a slight whine... Even on eco mode it was still loud...is it because of it being new? So once it runs in, it would be better?
I used the TW550 (750) as a reference and found it was very quiet compare to my 2030. Even at more than 12' away I can still hear my PJ.
Another thing I noticed was the lamp hours didn't increase even after I watched 2-3 movies... Still at 0... Software error?
okitoki is offline
post #342 of 627 Old 08-31-2014, 09:17 AM
When PJ is on stand by mode (when power is shut off), should the power light turn from blue to orange (or red)? My old PJ and other AV gadget turns orange (or red) when power is on standby mode.
Is this unique for 2030 or it's just my PJ power light issue?
post #343 of 627 Old 08-31-2014, 09:33 AM
ben38's Avatar
Quoted: 331 Post(s)
Liked: 170
Originally Posted by okitoki View Post
Hi
All Epson projectors read 0 for the first 10 hours of bulb life. Nothing wrong.
ben38 is offline
post #344 of 627 Old 09-02-2014, 04:48 AM
NoVaT's Avatar
Mine remains blue as well? No problem, just the way it is.
NoVaT is offline
post #345 of 627 Old 09-02-2014, 06:51 AM
Dagg21's Avatar
I am using Grey (Stewart Filmscreen Firehawk)and my only complaint is the skin color I have spent alot of time trying to get it just right. I do like the darker blaks it provides and I dont see any negative issues with whites. For me to be able to game on it with lights on (dimmed) and still have it very watchable was a big factor in that decision. All things considred I made the right choice for how I use it.
Not my pics but others on the web
https://www.google.com/images?q=stew...Q&ved=0CBQQsAQ
Dagg21 is offline
post #346 of 627 Old 09-04-2014, 11:40 PM
Liked: 0
HI, i hope this thread doesnt get lost in the sea of threads.. Help, I bough this Epson powerlite home cinema 2030 projector and it worked perfect for the first two months and know its not working: Before I just turned it on, and in a few seconds the image appeared, know it takes about 3 o 5 minutes for something to appear. Before I had connected a blue ray via HDMI and it worked perfectly fine, and know it says no signal. The weard part is that the DVD player does work with the RCA cable. SO theres is two problems, i dont know if related but they both appeared at the same time: slow projecto, and no signal in HDMI.
Ive tried: 1) checking out the blue ray works and the HDMI cable works, they both work fine. 2) Resetting the projector settings 3) cleaning filter 4) searching for answers in internet, no forums, no answers, except this forum 5) the temperature or lamp light do not flash
Any ideas??? I miss my expensive projector
Elisa
elisanavarro is offline
post #347 of 627 Old 09-05-2014, 09:57 AM
Mr.G's Avatar
Quoted: 742 Post(s)
Liked: 421
Elisa
You don't mention the length of your HDMI cable, plus you don't state whether you are running your connection through a audio/video receiver.
From the symptoms you state I would guess the problem lies with your HDMI cable. The fact that the cable works from your Blu-ray player to your HDTV(?) means nothing. Many HDMI cables can operate right at the edge of HDMI specifications but can begin to fail with time, the reason is not always clear.
The symptoms you mentioned are extra long times to establish handshake between source (Blu-ray player) and sink (Epson 2030).
And the fact that you are getting the 'no signal' available message.
If indeed it is the HDMI cable this is the easiest thing to remedy, swap it out with a new cable.
If this does not solve your issue then the problem lies somewhere else in the HDMI pathway between devices.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #348 of 627 Old 09-05-2014, 10:26 AM
therealdjnugz's Avatar
Quoted: 84 Post(s)
Liked: 33
Can anyone recommend a good ceiling mount for the 2030? It needs to have at least a 16" extension. This is my first projector,so the universal mounts make me nervous as far as not fitting the projector. So any recommendations would be greatly appreciated. Thanks!
therealdjnugz is offline
post #349 of 627 Old 09-05-2014, 02:52 PM
Quoted: 84 Post(s)
Liked: 33
So far Im leaning towards a Peerless mount. A lot more expensive than the other mounts on Amazon I've seen, but seems more trustworthy.
post #350 of 627 Old 09-08-2014, 10:37 AM
Dagg21's Avatar
I ended up using this from amazon and also a friend who used it:
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Took few minutes for my buddy and I to figure it out (attaching to projector) but works great I needed the extension pole as well for my setup. Hard to comment on how long it took overall since we had alot of other basement related challenges. I wouldnt consider it super easy out of the box attach and go but certainly fits this model and worked for me.
Dagg21 is offline
post #351 of 627 Old 09-08-2014, 06:31 PM
Quoted: 84 Post(s)
Liked: 33
I looked at that one, but ended up getting a Peerless mount on Amazon for $114. It's a lot more expensive but it's really nice from the videos on it I saw.
post #352 of 627 Old 09-10-2014, 06:46 AM
DanHorse's Avatar
Quoted: 28 Post(s)
Well, I am bummed out... I was going to buy this, then double checked the throw distance calculator and realised my room is a foot too short for it.
Why are there no small form factor 1080hd LCD projectors with a more regular throw as well? looks like i will have to go DLP, which I do not like as it is not a relaxing image to me.
Best,
Dan
DanHorse is offline
post #353 of 627 Old 09-10-2014, 11:30 AM
Liked: 2
I used the Sanus universal mount vmpr1b. Seems sturdy and was easy to mount. The drop tube is a bit long, so I will cut and retread when I get my screen up. Looks pretty nice to me!
post #354 of 627 Old 09-10-2014, 12:29 PM
Ftoast's Avatar
Quoted: 2214 Post(s)
Liked: 702
Not sure if you already saw it, but a few threads down there's a quick write-up for the upcoming Epson 3000series that will likely thwamp the 2030's contrast while offering more flexible throw (and likely a shorter starting distance) starting around $1200 and likely falling a little lower after release.
Should be out soon-ish and sounds worth the wait if you don't like how even a 6X DLP looks.
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is online now
post #355 of 627 Old 09-11-2014, 12:42 AM
DanHorse's Avatar
Quoted: 28 Post(s)
Thanks mate, another forum member mentioned those to me yesterday as well, I will just have to hold for those if the throw is able to be longer than 2030
Best,
Dan
DanHorse is offline
post #356 of 627 Old 09-17-2014, 09:45 AM
Liked: 0
Hi Everyone,
I got this Epson projector and have it connected to a gaming laptop (Core i7, 16 GB ram, SSD, Nvidia GTX 675, 1.4 HDMI cable)
I have a minor problems with the refresh rates. Actually they are not "problems" i just dont really know how to set up the Epson with a computer.
2d
I wanted to get 24hz for more film like movies, but when is set the Epson's refresh rate to 24 hz the movies (1080p) becomes jigging. It plays well at first, but after 20 sec it starts jigging, then its okay again and do this all over again in the whole movie. So 20 sec smooth playback, then jittering, then smooth...
I have tried PowerDVD, Total Media, Media Player Classic, Windows Media player... but always got the same problem when i use 24hz.
Everything is perfect when i use 60hz... :S
Whats is the correct way to set that 24 hz in Windows?
3d
I watched some SBS 3d movies in 60hz Windows settings. It was "okay"...
When i set it to 24 hz i got that jittering effect again, but its more pleasant to watch in 24 hz. I dont know why, its just more better for my eyes...
Should i use 60hz or 24hz for 3d?
One more thing:
As far as i know this projector operates in 240 or 480 Hz in 3d.
Why i cant change my Windows refresh rate to these settings? The max i can go is just 60 hz.
Or is this a different refresh rate? I dont really get this...
Thanks your replies!
Zoltan
Projector JVC DLA-X5000W Media player Dune HD Base 3D AV Receiver Pioneer SC-2022 Speakers FRONT: Klipsch RP-280 CENTER: Klipsch RP-450C SUBWOOFER: Klipsch R-115SW SURROUND: Klipsch RP-250S
djkutasi is offline
post #357 of 627 Old 09-21-2014, 10:11 PM
Liked: 0
I'm shopping for glasses, how can I tell what's compatible with this projector? From what I understand there are two types of 3d RF glasses, how do I tell the difference between the two and know which ones will be compatible?
What are best low cost 3d glasses for this projector? Are the Samsung SSG-5100's good?
deewhy is offline
post #358 of 627 Old 09-22-2014, 10:13 AM
BDUB619's Avatar
Quoted: 374 Post(s)
Liked: 238
That's what I bought for this projector and they work great, no problems. I only wish the lenses were a little bigger to cover my eyes more but it is what it is. Plus, they're inexpensive compared to the $99 Epson glasses.
Yodabutt likes this.
Sony 75" X900e
Sony 70" W850
Xbox One GT: JonnyRingo619
PS4 GT: Ringo619
BDUB619 is offline
post #359 of 627 Old 09-22-2014, 11:46 AM
Dagg21's Avatar
I have 2 models of 3d glasses at home one being the samsungs. They work just fine but i prefer the other pair since they "wrap" more. Will have to figure out what make/model they are and update this post. That is simply personal preference as the perform the same.
Dagg21 is offline
post #360 of 627 Old 09-22-2014, 04:15 PM
joe221's Avatar
Quoted: 57 Post(s)
I have the 5100s and they are just fine.
Joe in West Los Angeles, CA
joe221 is offline
3lcd Projector 2200 Lumens , epson 2030 , Epson Powerlite Home Cinema 2030 3lcd Projector , sony bdp-s6700 , yamaha yht-4920ubl
