The Offical Epson 2030 2D/3D 1080p 3LCD Projector Thread - Page 15 - AVS Forum
 24Likes
post #421 of 429 Old 12-18-2014, 09:25 PM
sysebo's Avatar
After trying several different cables, I ended up with Monoprices's Redmere cables. They are high speed cables that are rated to handle 1080p, 3D, and 4K. They worked fine for the first few days, and will occasionally work currently with the PS3, usually when I unplug it, use it in another room, then reattach it to the cable feeding the projector.
The cable plays 1080p fine, and works flawlessly with my Panasonic tv.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Sysebo
sysebo is offline
post #422 of 429 Old 12-18-2014, 10:38 PM
Sean Spamilton's Avatar
Quoted: 101 Post(s)
Liked: 137
Any idea if this mount will be appropriate for a 2030?
Hey all, as above, I'm wondering if this can be used with a 2030..
http://www.amazon.ca/Universal-Exten...pr_product_top
It certainly looks like it would fit the bill - I'll be hanging it from an 8 foot ceiling and it would be nice to have the extra versatility as I don't intend to use keystone correction so need it at an exact height.
Sean Spamilton is offline
post #423 of 429 Old 12-18-2014, 11:46 PM
little pebble's Avatar
need something cleared up..
Is it true with this projector ceiling mounted it needs to sit 7-10cm below the top of the screen?
little pebble is offline
post #424 of 429 Old 12-18-2014, 11:55 PM
HDTVChallenged's Avatar
Liked: 154
Depends on the screen size, but that looks about right: 3 to 5 inches
HDTVChallenged is offline
post #425 of 429 Old Yesterday, 04:29 AM
wanting about 100 inch screen.... max 120
post #426 of 429 Old Yesterday, 10:21 AM
Liked: 154
Right ... the lens should be between 3 to 5 inches below the top edge of the screen. You might be able to adjust the physical pitch of the PJ mount to move the image up or down +/- 0.5 inches without getting into keystone issues. Still, you want to get it as close as possible. This is a case where you probably want to mount the PJ first, line the image up on the wall, then line the screen up to the image. Or, an adjustable drop electric screen might make life a bit easier.
post #427 of 429 Old Yesterday, 10:33 PM
yikes that probably hit the roof of the van in the garage... this is gonna take some work
post #428 of 429 Old Yesterday, 11:19 PM
Liked: 154
Yep ... I can see where it might become a "navigational hazard" for taller folks. I suppose it depends a bit on your comfort vs. screen height threshold.
EPSON does have a good throw vs. size vs height calculator (flash based) at their website.
post #429 of 429 Old Today, 02:07 AM
yep thats were i got the 5-7cm from...
post #430 of 429 Old Today, 11:05 AM
Liked: 154
For the record: On my ceiling install with ~99" diagonal image ... the center of the lens is ~18.5" from the ceiling (the top of the PJ case is ~21.5" from the ceiling.) The top edge of my screen (image) is ~13.5" from the ceiling; and since I was a bit "off" with the screen alignment, I had to pitch the PJ down to make up for about 0.25 to 0.5 inches of overshoot. (... or I didn't get the pitch screws tightened down enough initially and it slipped upward.)
I haven't taken the time to "perfect" the alignment since, apparently, I'm still in an endless loop trying to decide on a permanent screen solution.
Epson Powerlite Home Cinema 2030 3lcd Projector , 3lcd Projector 2200 Lumens
