Epson 5020UB shows a red patch visible when a scene has dark/black background - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-02-2013, 03:17 PM - Thread Starter
droidvideo's Avatar
I bought 5020UB projector in December of 2012. It is great 3D and 2D projector. I installed it in media room projecting on 120" screen. Around a month back, I saw a red patch visible when a scene is pitch black. Cleaning the lens cover etc didn't fix the problem. Nor the steps that Epson support asked me to perform helped either.
The red dot is not seen when projecting the blue pattern image. It can be seen only when it is dark/black picture. I connected a laptop directly and used MS paint application to draw a black rectangle that covers the area where this red dot (around 1 in in diameter). I can see it clearly. Then I used a white napkin and moved it closely to the lens (me standing right below the projector). I moved it to the area where the red dot is seen. I can see a small mesh of red lines on white napkin when it is covering the area in question.
Is it a known issue?
Joe
droidvideo is offline
post #2 of 3 Old 09-03-2013, 11:01 PM
Tinman's Avatar
Liked: 33
Probably a spec of dust on one of the polarizers. LCD projectors are prone to this, some more than others depending on how well they "seal" the light engine. It can never be totally sealed because the LCD block needs air cooling as well as the lamp.
Welcome to the darkside.....
Tinman is offline
post #3 of 3 Old 09-15-2013, 09:18 PM - Thread Starter
droidvideo's Avatar
Epson support is world class. They sent me replacement unit as the unit is still under warranty.
Epson 5020ub Powerlite Home Cinema 3d Front Projector , Epson
