Dust covers for ceiling mounted projectors? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-03-2013, 10:55 AM - Thread Starter
Project H's Avatar
Does anyone know where I can find one? I won't be using my projector on a regular basis and wanted to prolong the life of the projector and maintenance with the filter and avoid dust blobs on my 8350. Is there a dust cover that I purchase for my projector that has a slit for where the ceiling mount is?
I also need to sand some drywall patches when the wires for fished through so this is also why it's important for me.
thanks!
Project H is offline
post #2 of 7 Old 09-03-2013, 01:37 PM - Thread Starter
Project H's Avatar
The only one i found is by visual apex
anyone else know of any or use this one before?
http://www.visualapex.com/accessories/accessory_details.asp?chPartNumber=DUST_COVER&MFR=VisualApex&Type=Misc
post #3 of 7 Old 09-03-2013, 06:19 PM
Bohanna's Avatar
Liked: 24
thanks!
#1- you can cover the projector with a glad bag while you sand the drywall.
#2 Clean the filter every 30 or so hours and you should never have a dust blob problem. Depending on the projector If you can place an auto air filter over the air intake it will be even better. You can put the filter on with Velcro. You can get the filters at your local wally mart in the auto section. There are many sizes to choose from. - Bohanna
Bohanna is offline
post #4 of 7 Old 09-03-2013, 06:29 PM - Thread Starter
Project H's Avatar
i have an epson 8350... not sure how i would use an auto air filter intake filter. cosmetically it would look odd and doesnt the projector have a filter on it itself that i can just clean?
also, does anyone put a lens cover on their projectors? i'm not doing this as it will change the zoom/focus whenever i take it on/off.
post #5 of 7 Old 02-27-2014, 02:32 PM
bigbadbob's Avatar
Forgive my ignorance but wont the projector overheat with a dust cover?
Just curious as I am considering an Epson 5030.
How about lens covers?
RG
Klipsch Rocks!
bigbadbob is offline
post #6 of 7 Old 02-27-2014, 04:57 PM
bluer101's Avatar
Quoted: 345 Post(s)
Liked: 278
RG
The dust cover is for when not in use.
old corps likes this.
Projector & Screen: Epson 5040ub Elite Screens 100" Electric Video: Oppo 103d Audio: Denon 4520ci Speakers: Infinity RS5 (LW L C R RW) Infinity RS1 (LH RH) Infinity Beta ES250 (SL SR) Subwoofers: 2 SI18d4 Martycubes with iNuke3000dsp and 2 Infinity BU120 Shakers: 4 ADX shakers with Dayton SA230 amp
My Builds--Media console build----Martycube build----ADX Bass Shaker Install
bluer101 is online now
post #7 of 7 Old 04-22-2014, 02:12 PM - Thread Starter
Project H's Avatar
back to the top.. just wanted to get some updated feedback on this. my projector has been sitting idle for the last few months. does anyone recommend a dust cover? i dont use the lens cover as im worried it will change the focus/zoom.
Epson Powerlite Home Cinema 8350
