Benq W1070 - HDMI issues - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 09-03-2013, 03:52 PM - Thread Starter
nuns4president's Avatar
I just recently purchased the W1070 and I can't play any devices through the HDMI connections.
*I tried a blu-ray player and got video, but I couldn't get sound.
*I tried another blu-ray player I had and I couldn't get a picture or sound, but the projector showed that it detected a source.
*Last, I tried Apple TV and I got a picture with sound, but when I went to play any video I got an "HDCP error".
I tried multiple HDMI cables that I had with no luck. I am wondering if there is a setting I need to adjust between the devices to get the HDMI to work properly. I was hoping someone on these forums might have some insight as to what the problem could be.
I am going to go buy a new high speed HDMI cable tonight to see if that will help with these issues.
nuns4president is offline
post #2 of 11 Old 09-03-2013, 05:29 PM
DtommyD's Avatar
That's gotta be a cable problem right? If your getting hdcp errors I'm saying its the cable. Try a short 3ft one. Or there is something wrong with the projector. Are you running it through a splitter? That could do it.
Also. Make sure you restart everything. Pull the plug for a minute just for fun. Including the projector. Hopefully do that one just once. Is everything grounded properly?
If your buying a new projector, buy more lumens than you will use. Running it in "Eco Mode" makes your bulb last 20-40% longer and reduces noise and heat.
DtommyD is offline
post #3 of 11 Old 09-04-2013, 05:48 AM
LFM2's Avatar
I've posted this before. The HDMI connectors are a problem. I trimmed about a millimeter of the plastic from the connector so that there is a small space between the plastic of the connector and the projector body when its fully seated. This fix has worked for several others. I just used a box cutter knife.
LFM2 is offline
post #4 of 11 Old 09-04-2013, 06:01 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 98
The Monoprice port savers also work.
rwestley is offline
post #5 of 11 Old 09-04-2013, 08:40 AM - Thread Starter
I bought a high speed slim HDMI and that did the trick. The connectors were slimmer as well so maybe they seated a better connection. I will try and trim down one of my other cable connectors and see if that was the original problem.
Either way thanks for the replies!
post #6 of 11 Old 09-04-2013, 10:04 AM
badshah2000's Avatar
I bought a Benq from Costco at what I thought was an excellent deal ($899 for the projector and two pairs of Benq 3D glasses) but returned it utterly frustrated after experienced flaky HDMI connections. I think I gave up too soon though by having been turned off by this QC issue.
badshah2000 is offline
post #7 of 11 Old 09-05-2013, 05:58 PM
OZReddog's Avatar
Liked: 32
Obviously you did not read the Benq W1070 thread before returning the projector. This problem and the solutions have been discussed a number of times there. Pity it is a great projector.
OZReddog is offline
post #8 of 11 Old 04-04-2016, 07:36 PM
Quoted: 33 Post(s)
Liked: 0
Could this be why the speaker is making big noises instead of the actual sound? I got the HT2050 Benq
sugirthan7854 is offline
post #9 of 11 Old 07-20-2017, 04:10 PM
Liked: 0
I just purchased the Benq W1070 and I can't play from some devices through the HDMI connections.
The only thing that works is from my satellite receiver, it`s a vu solo
I also just bought from ebay..a panasonic DMP-BDT300 to watch 3D movies.
The projector can`t detect the signal from the panasonic , the player itself works when it is connected to my tv.
I have tried to use the same hdmi cable..so it seems like there is no cable issues here.
Any solution? Help
Jones83 is offline
post #10 of 11 Old 07-21-2017, 02:52 PM
rocklee's Avatar
Quoted: 216 Post(s)
Liked: 69
Had no idea that the W1070 would this problematic, thanks for bringing it to my attention.
XGIMI H1 (SmartProj) - Swan M200MkIII (Speakers) - Bluedio UFO Plus (BassHead) - Sony MDR CD3000 (UnicornHead)
__________________________________________________ ______________________________________________
Just kicking butt everyday :-)
rocklee is offline
post #11 of 11 Old 07-21-2017, 11:54 PM
dreamer's Avatar
Quoted: 1053 Post(s)
Liked: 318
Any solution? Help
I had this issue 3 years ago running all my HDMI sources through my 10yr old Harmon Kardon receiver. The W1070 would search for a source, lock on, then drop a few seconds later.
I bought a $40 HDMI 4 port switch from Monoprice.com that also separated the audio to feed my AVR via SPDIF coax. Never a problem since then. The bonus is that my AVR only had two HDMI inputs and I have since added a second bluray player and a Roku stick, so the 4 inputs come in handy.
Kirk Ellis
BenQ W1070 VuTec 122" Screen
Harmon Kardon AVR 247 Parasound L&R Amp
Psycoustic Mark III L&R Towers, Boston Center
Energy Take 5 Surrounds, HSU Research Sub
dreamer is online now
Benq W1070 3d Ready Dlp Projector 1080p Hdtv , Benq W1070 1080p 3d Projector
