LG PF80G First world mini-projector full led 1080p - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #271 of 695 Old 10-28-2013, 10:59 AM
DJPAUL's Avatar
@Jasinto
No Opera Soap Effect picture is every Second perfect
And with the superresolution i dont see any difference
And no sry no Experience with dlp PJ
DJPAUL is offline
post #272 of 695 Old 10-28-2013, 03:29 PM
pstas's Avatar
Dear DJPAUL,
Are you sensitive to the Rainbow effect? Have you ever experienced it on the PF80G?
pstas is offline
post #273 of 695 Old 10-28-2013, 03:35 PM
DJPAUL's Avatar
Yes i am
DJPAUL is offline
post #274 of 695 Old 10-28-2013, 04:14 PM
espetodesardina's Avatar
Location: Málaga, Andalusia in the Spanish Costa del Sol
Liked: 45
DJPAUL, after you have tested which would be your score from 1 to 10?
Have you tried test mkv files by the usb port?
Why two usb ports?
Do you feel any improve about the HW300G in terms of smoothness or compatibility?
Is compatible with DTS or is only for Korean version like happens in the PB60G?
Do you think the PF80G would be enough brilliant for 3D movies with the glasses on?
With videogames...any input lag?
espetodesardina is offline
post #275 of 695 Old 10-28-2013, 04:45 PM
kenoh89's Avatar
Quoted: 437 Post(s)
Liked: 83
I have the same problem with the Acer k750 but more pronounced! best way to fix it is to have the projector perfectly align with the screen and minimalize focus by balancing the left and right parts of the screen till the right starts to look good but the left is not out of focus too much. "You will lose some sharpness with the left but the right will looks better!" Use a wall of text from a computer to help with the calibration. It's easier.
kenoh89 is offline
post #276 of 695 Old 10-28-2013, 04:45 PM
kenoh89's Avatar
Quoted: 437 Post(s)
Liked: 83
kenoh89 is offline
post #277 of 695 Old 10-28-2013, 04:55 PM
indio22's Avatar
Quoted: 21 Post(s)
Liked: 46
Originally Posted by DJPAUL View Post
Yes i am
If the PF80g has no rainbows, that would be a significant improvement over the PA70g, not to mention other DLP projectors. I own the PA70g and have been very happy with it in terms of price and my family usage needs, but I do see some rainbows with it, particularly in high contrast areas or black and white films. No rainbows would be nice. Also thanks DJPAUL for all the info you have provided.
indio22 is offline
post #278 of 695 Old 10-28-2013, 05:48 PM
DJPAUL's Avatar
I give the PF80G 8/10
Not 10 because of the Focus issue and the price.
The PF80G in my opinion is the best LED PJ at the moment but only for people who watch alot of 1080p movies and who dont care about the price
For me im not so sure if i should stay with the PF80G because im just watching for 90% 720p Animes and on the PF80G they look the same as on the HW300Y
If the PF80G would cost only 600-700€ i would definitely stay with it but its very expensiv in my opinion
Yes 3D would be a nice feature and the PF80G is strong enough for 3D
Yes MKV work great
2x USB sry but i dont now why ^^
DTS i dont try but i think it works
Dont test it with videogames(i will try it for you later the day/with Wii U(1080p game) or PS3(720p game) what would you like to see?)
DJPAUL is offline
post #279 of 695 Old 10-28-2013, 06:09 PM
kenoh89's Avatar
Quoted: 437 Post(s)
Liked: 83
Some say the Acer k750 is the best currently for contrast and shadow detail and the Viewsonic is the best for brightness and sharpness? Both are said to be better then the LG in brightness/contrast too. Although nobody has put up a comparison.
kenoh89 is offline
post #280 of 695 Old 10-28-2013, 06:20 PM
Liked: 45
Input Lag and smoothness compared to HW300Y
post #281 of 695 Old 10-28-2013, 11:26 PM
kenoh89's Avatar
Quoted: 437 Post(s)
Liked: 83
Hopefully someone puts up a comparison with current LED projectors like Acer k750 and Panasonic RZ470u and Optoma HD91
kenoh89 is offline
post #282 of 695 Old 10-29-2013, 02:01 AM
Razerian's Avatar
@Kenoh
I don't think you should expect the HD-91 to be compared anytime soon, as it's not even out yet and isn't planned to be released until december according to Optoma.
Also it will be a lot better than the PF80G as it has 3-4x the pricetag of the Pf80G with a pricetag of 4000+€ or 5500+$ according to Optoma. They even noted it might be more expensive than that. So at that price it should beat the PF80G quite badly, or at least I would assume so.
Razerian
Razerian is offline
post #283 of 695 Old 10-29-2013, 02:32 AM
kenoh89's Avatar
Quoted: 437 Post(s)
Liked: 83
OK? But what about the Panasonic RZ470u, the Viewsonic and ACER. How do those compare? The Panny can be had under $3000. some I've even seen at around $2800 so at least these can be compared. By the way I heard from a close source that it might be under $4000 hear in the US. The reason why it may be priced higher in the UK is because of taxes?
kenoh89 is offline
post #284 of 695 Old 10-29-2013, 03:00 AM
Razerian's Avatar
Well, I am in Denmark, but the information was sent to me from the part of Optoma that is in Norway.
But it does seems that we europeans get screwed with the prices quite a lot when it comes to electronics, generally a 30% gain in price once it crosses the atlantic ocean...
By the way, from what I have read in the K750 reviews it weaknesses should be that it can have a hard time handling action/highspeed scenes in movies, I have not tested this though so I can say for certain it is true.
This is actually why I am aiming to get the PF80G instead of the K750, since it shouldn't have that problem.
Razerian
Razerian is offline
post #285 of 695 Old 10-29-2013, 03:17 AM
kenoh89's Avatar
Quoted: 437 Post(s)
Liked: 83
I never had a problem with high speed action for movies or games! DLP compared to LCD/LCOS is much better at fast moving scenes and has a faster response for games. Things like fast moving scenes look better when I put my Home Theater receiver on game mode. On my PC it's even better for movies as I overclock my refresh rate!
kenoh89 is offline
post #286 of 695 Old 10-29-2013, 01:18 PM
CharlesZ7's Avatar
DJPAUL,
Thanks for all the info.
Q: I take it the PF80G does NOT have upscaling? With everything else they threw in there I'm surprised they skimped on this, but again it's LG and they tend to miss critical things.
CharlesZ7 is offline
post #287 of 695 Old 10-29-2013, 04:23 PM
DJPAUL's Avatar
DJPAUL is offline
post #288 of 695 Old 10-29-2013, 04:25 PM
DJPAUL's Avatar
Yes the threw everything in there but no upscaling -.-
CharlesZ7 likes this.
DJPAUL is offline
post #289 of 695 Old 10-29-2013, 04:35 PM
DJPAUL's Avatar
I tested it with a wii u game (zelda wind waker1080p) and there was no inputlag
My hw300y dont have inputlag too
But on the pf80g videogames looks amazing (much better as hw300y) but wii u 1080p looks much better as ps3 720p
Razerian likes this.
DJPAUL is offline
post #290 of 695 Old 10-29-2013, 05:11 PM
DJPAUL's Avatar
DJPAUL is offline
post #291 of 695 Old 10-29-2013, 07:10 PM
PENDRAG0ON's Avatar
Liked: 574
Can you show how native 720p content looks on this? If the US model lacks a scaler I want to know what I would be in for.
PSN - Pendragoongp
NNID - Pendragoon
PENDRAG0ON is offline
post #292 of 695 Old 10-29-2013, 11:14 PM
claudiolsa's Avatar
Thank you for the videos DJPAUL! Wind Waker HD looks awesome on this projector. Nice and vivid colors and satisfactory black level for me. Mario 3D World will be amazing in this!
And no focus issues in the HUD on top right. I was waiting for see this. Thanks again!
Btw, you are projecting on the wall? (In the Wind Waker video in case)
PS: sorry about my english, I'm very bad in it tongue.gif
claudiolsa is offline
post #293 of 695 Old 10-30-2013, 07:47 AM
DJPAUL's Avatar
No this is my screen but the pf80g cant fill all of my screen;)
DJPAUL is offline
post #294 of 695 Old 10-30-2013, 10:42 AM
HTCrazy's Avatar
Called LG about the 85U release date and got some interesting info.
Will it definitely be released in the US? Yes and we're getting flooded with calls about this projector.
When? We don't know but all the new models will be announced on Black Friday (November 21st?). Check the website then for availability.
Do you think it will be released this year before Christmas? Yes.
Will the US version be the same as the European model? Yes. Same specs exactly.
What is Miracast? (listed on their website): It's special software that will allow your PC or cell phone to display directly on the projector wirelessly.
Can it work wirelessly with your Blu Ray player? No. It needs the special software that's only available on cell phones or PC's.
Starting to regret getting the OPPO instead of an HTPC...
HTCrazy is offline
post #295 of 695 Old 10-30-2013, 10:46 AM
PENDRAG0ON's Avatar
Liked: 574
Black Friday is the day after Thanksgiving in the US. It is always the last Friday of the month.
PSN - Pendragoongp
NNID - Pendragoon
post #296 of 695 Old 10-30-2013, 11:14 AM
Liked: 45
DJPAUL thank you
What firmware version is on PF80G?
Have you had to upgrade the firmware on line?
These are screenshots of my PB60G from Star Wars Ep III on 106", can you do a Vs with the PF80G?
Have you test my settings?
post #297 of 695 Old 10-30-2013, 11:18 AM
DLPProjectorfan's Avatar
Quoted: 21 Post(s)
Liked: 45
Did they give a hint on what the price will be here in the USA ?
DLPProjectorfan is offline
post #298 of 695 Old 10-30-2013, 11:43 AM
t-n-o's Avatar
Quoted: 69 Post(s)
Liked: 32
Mmmh. What's if the Blu Ray player supports WIDI/WIFI Direct? Mine does and the PF80G does it too, shouldn't it work in this case? If not i'm out cause this was one of reasons why i've waited for the PF80G instead of buying a K750 or PRO9000.
t-n-o is offline
post #299 of 695 Old 10-30-2013, 12:05 PM
breezer001's Avatar
To t-n-o
You need a sender and a receiver to send a signal wirelessly. Bluray player and projector both are receiver so it won't work.
On the other hand, a computer with bluray may theorically works as miracast/widi mirrors the screen but bandwich may also be a problem because of high bitrates.
breezer001 is offline
post #300 of 695 Old 10-30-2013, 12:11 PM
t-n-o's Avatar
Quoted: 69 Post(s)
Liked: 32
Ah, thx. In this case i don't have to wait for more reviews and can go for the Acer instead. It's about 400EUR(550$) cheaper.
t-n-o is offline
Lg Electronics Pa70g Micro Portable Led Projector , Lg Pa75u Dlp Home Theater Projector , lg pf80g , Optoma Hd91 Full Led 1080p Projector
