5020 throw distance? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-06-2013, 12:05 PM - Thread Starter
gec5741's Avatar
Quoted: 200 Post(s)
Liked: 91
I'm looking at maybe the epson 5020 or 6020 for a future finished basement. If mounted on the back wall my throw would be around 15' from lense to screen (could be a bit less then that). Would I be ok with that distance on a 120 inch 16:9 screen or would I be better off mounting it from the celing a little closer?
Thanks in advance!
gec5741 is offline
post #2 of 3 Old 09-06-2013, 12:11 PM
walterappleby's Avatar
Quoted: 25 Post(s)
Liked: 77
Should be fine. That's just a bit closer than the mid point zoom range for those projectors to a 120" screen.
Projection Calculators put it in the 18FL range.
http://www.projectorcentral.com/Epson-PowerLite_Home_Cinema_5020UBe-projection-calculator-pro.htm
http://www.projectorcentral.com/Epson-PowerLite_Pro_Cinema_6020UB-projection-calculator-pro.htm
walterappleby is offline
post #3 of 3 Old 09-06-2013, 12:47 PM - Thread Starter
gec5741's Avatar
Quoted: 200 Post(s)
Liked: 91
That's what I thought. I did look at a calculator but I wanted to hear it from a person. I wasn't really sure if I was looking at the results right or not.
gec5741 is offline
Epson 5020ube Powerlite Home Cinema 3d Wireless Front Projector , Epson Powerlite Pro Cinema 6020ub 3d 1080p 3lcd Projector
