5020 split screen work around - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-09-2013, 01:05 PM - Thread Starter
benine's Avatar
I only ran 2 hdmi cables to my projector mount position and wanted to use the 5020ub split screen. I hooked my htpc to my 2nd hdmi and used a hdmi to vga converter. So now i can split screen and watch the tv and surf the web at the same time. Any other work arounds out there that other folks have used I would be glad to hear them.
benine is offline
post #2 of 2 Old 09-13-2013, 02:18 PM
fitbrit's Avatar
Quoted: 54 Post(s)
Liked: 50
I plan on doing the same when I get my 5020 eventually. I also ran two HDMI cables, and I have a $15 HDMI to VGA converter sitting in my Amazon cart. I intend to connect two gaming PCs for side by side racing simulations. I already have two racing cockpits in front of my 120" screen. Currently, I use one PC and over/under split screen. Side by side (with separate audio going to headphones) will be great.
I don't know of any other workarounds you can use.
fitbrit is offline
Epson 5020ube Powerlite Home Cinema 3d Wireless Front Projector
