Need help with setting up 3D properly - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 09-10-2013, 04:30 PM - Thread Starter
Prime316's Avatar
Quoted: 185 Post(s)
Liked: 205
I just got my 120" Elite fixed frame screen mounted today to go along with the Benq w1070 that I ceiling mounted a few days ago. Lovvvvvve the screen and the projector is pretty nice too.
I've never watched a movie in 3D so I'm not exactly sure what the image should look like. I have a pair of the 144 hz glasses that work with the projector. The problem is when I play the movie in 3D Full HD, the image looks.....
Well I can only describe it as if I were crossing my eyes and looking at the screen. I can't really read any of the print on the menus either. I'm not sure what I'm doing wrong.
Thanks in advance.
Projector: Benq W1070 1080p 2D/3D
AVR: Denon X2200W
Mains: Klipsch RF-62ii x 2
Center: Klipsch RC-62ii
Surrounds: Klipsch RS-42ii x 4
Subs: Dual Hsu VTF-15H's
Prime316 is offline
post #2 of 9 Old 09-11-2013, 07:31 AM - Thread Starter
Prime316's Avatar
Quoted: 185 Post(s)
Liked: 205
Really, guys?
All these posts here about 3D being great on this projector and that projector and no one can give me any advice?
AVR: Denon X2200W
Prime316 is offline
post #3 of 9 Old 09-11-2013, 08:08 AM
tucsondave's Avatar
Sounds like your sync polarity is reversed for your glasses. Check your projector's 3D menu for a "reverse sync" or similar control.
td
tucsondave is offline
post #4 of 9 Old 09-11-2013, 01:28 PM - Thread Starter
Prime316's Avatar
Quoted: 185 Post(s)
Liked: 205
Will do. Thanks
AVR: Denon X2200W
Prime316 is offline
post #5 of 9 Old 09-11-2013, 02:03 PM
regalman82's Avatar
What Glasses did you get? Watched star trek last night and was blown away at the quality
Blake
regalman82 is offline
post #6 of 9 Old 09-11-2013, 02:12 PM - Thread Starter
Prime316's Avatar
Quoted: 185 Post(s)
Liked: 205
Sainsonic 144hz...ssz200dlb
http://www.amazon.com/SainSonic-reg-SSZ-200DLB-Rechargeable-ViewSonic/dp/B0085JBI6S/ref=sr_1_1?ie=UTF8&qid=1378933876&sr=8-1&keywords=sainsonic
AVR: Denon X2200W
Prime316 is offline
post #7 of 9 Old 09-11-2013, 02:13 PM - Thread Starter
Prime316's Avatar
Quoted: 185 Post(s)
Liked: 205
Blake
So you didn't have to switch anything up on the projector?
AVR: Denon X2200W
Prime316 is offline
post #8 of 9 Old 09-12-2013, 07:10 AM
regalman82's Avatar
No i have a PS3 hooked up thru a dennon 2113 to the benQ 1070 and all i do is pop in the 3d movie and it detects it automatically.
I started with the Sainsonic 144hz and then switched to the monoprice 144hz versions, much better with the red flash and to me the contrast ratio .
Blake
post #9 of 9 Old 09-12-2013, 02:48 PM - Thread Starter
Prime316's Avatar
Quoted: 185 Post(s)
Liked: 205
Blake
Thanks. I believe I got mine working but the flashes are a pain to deal with. I wear glasses already so wearing two pairs gets annoying really fast.
AVR: Denon X2200W
Prime316 is offline
Benq W1070 3d Ready Dlp Projector 1080p Hdtv , Denon Avr 2113ci Receiver
