Optoma hd20 replaced color wheel? Now the color is off - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 09-21-2013, 09:43 AM - Thread Starter
tylermmoore's Avatar
I just replaced the color wheel on my optoma hd20 but now when I turn it on the color tint is off. Obviously it has something to do with the color wheel since I just installed it but wondering if anyone has any experience with this. Do you think the color wheel just needs to be cleaned? Just curious before I take it apart again.
tylermmoore is offline
post #2 of 11 Old 09-21-2013, 10:29 AM
jamnperry's Avatar
You have to go into the service menu and adjust the speed of the wheel. It's been discussed before.
jamnperry is offline
post #3 of 11 Old 09-23-2013, 05:32 PM
Tinman's Avatar
Liked: 33
That's correct. The new wheel has to be "timed" in the service menu. I don't have a link, but if you google it, you should find your answer. It's pretty simple.
Welcome to the darkside.....
Tinman is offline
post #4 of 11 Old 09-24-2013, 07:31 AM - Thread Starter
Thanks. for some reason I cant seem to find it but ill keep searching.
post #5 of 11 Old 09-24-2013, 07:28 PM
42Plasmaman's Avatar
Quoted: 20 Post(s)
Liked: 37
42Plasmaman is offline
post #6 of 11 Old 09-25-2013, 11:11 AM - Thread Starter
thanks. I get into the service menu and can adjust the color wheel index but still not getting the right colors. is there another setting in the service menu that I should be changing?
post #7 of 11 Old 09-25-2013, 12:59 PM
Quoted: 20 Post(s)
Liked: 37
You might have better luck getting an answer by asking your question in the HD20 thread.
2016
post #8 of 11 Old 09-25-2013, 01:15 PM
DarkVenture's Avatar
Did you disconnect and reconnect any ribbon cables? You may need to make sure they are seated properly and fully inserted into the connector.
DarkVenture is offline
post #9 of 11 Old 09-26-2013, 03:50 PM
Tinman's Avatar
Liked: 33
You DID remember to plug in the little cable for the color wheel SENSOR again, right? The index setting should fix it.
Tinman is offline
post #10 of 11 Old 09-27-2013, 12:31 PM - Thread Starter
So i messed around the index setting, had to put it all the way down around 70 vs 286 and it looks much better. Thanks for the help, i guess i didnt realize it had to go so much.
post #11 of 11 Old 09-27-2013, 02:07 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
display the gray scale gradient pattern form the AVS 709 disk and look for vertical banding, continue to adjust the index for the least or no banding.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
Optoma Hd20 Dlp 1080p Home Theater Projector
