Dust blobs in Vioewsonic PJD6235 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-21-2013, 03:48 PM - Thread Starter
ahabec's Avatar
Hello, I know this topic has probably been covered ad nauseam in this forum, but I'm new here, and a simple google search has less results; so if I'm being repetitive to past posts I apologize to all the veterans in advance.
When I put the projector in "blank" mode I can see the blobs quite clearly; this is the same as a very dark (or nearly black) scene in a movie. Now, when I defocus the lens totally, the blobs sharpen up and look like a starry sky (there's quite a few of them, but only the biggest ones show up as blobs in focusewd viewing; I suppose others may decrease contrast or something but this is not noticeable enough to be annoying).
When I stare into the lens at an angle (even in blank mode, the light is quite bright...) I can actually see the dust particles.
My question is this: Am I seeing dust stuck to the reflector mirror? That's what it seems like; BUT:
In out-of-focus, the "stars" also show outside the black square of the projected image, SO - does this mean I also have dust on the back of the lens.
AND FINALLY: Is the lens assembly airtight? can dust enter INSIDE between the lenses?
The projector is just 2 months old and within warranty. I am quite technically minded (I'm a watchmaker) but prefer to take it to the service center to fix. But if this problem will recur (I live in a dusty area, near the desert), is it very dangerous/difficult to clean on my own? the service center is a good one-hour drive away.
And also - are these things normally covered by the warranty? specifically in Viewsonic, I mean. Does anyone here know?
Jonathan
ahabec is offline
post #2 of 4 Old 09-21-2013, 06:16 PM
guitarman's Avatar
Quoted: 13 Post(s)
Yes they should be covered under warranty. I had about six blobs on my epson 1080ub. I opened up the top and used a bulb type sqeezer with a 2 inch cut tube. Puffed away down each panels ribbon connector while the black image was up and just blew them all away.
Tom/guitarman
VideoDementia
Are you twisted also?
http://www.videodementia.com/sales/TomWithWires.jpg
guitarman is offline
post #3 of 4 Old 09-21-2013, 06:16 PM
guitarman's Avatar
Quoted: 13 Post(s)
Tom/guitarman
VideoDementia
post #4 of 4 Old 09-22-2013, 07:13 AM - Thread Starter
ahabec's Avatar
I just spoke to a person at the service center and he said it may be a faulty DMD chip.
Could this be true if I also see the blobs OUTSIDE the projected image (as far as I understand the technology, the projected square IS the image of the DMD square, but magnified...).
Would this mean that I have dust on the back of the projecting lens - or another lens - which sits between the color wheel and DMD?
Wouldn't a faulty DMD show as dead pixels?
Guitarman - thanks, but I wouldn't want to blow air into the projector when it is connected to the mains and on.
Can anyone here tell me why Viewsonic projectors (at least the model I have) have no dust filters?
ahabec is offline
Viewsonic Pjd6235 Xga Dlp Projector
