flickering. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-22-2013, 02:57 PM - Thread Starter
randomdude2013's Avatar
So my projector is flickering. The picture I should say, and it will go away for the most part if I put it on economic. Wasn't sure if maybe it was because the blu ray player was on 1080p and the projector is on 720p. Also I don't know if the projector can install updates or not. I am still learning lol
randomdude2013 is offline
post #2 of 8 Old 09-22-2013, 03:42 PM
niggenz's Avatar
Some projectors struggle if you don't feed them native resolution. Try setting your blu ray player to output to 720p to see if solves the problem.
HTPC: Intel NUC (DC53427HYE) running OpenELEC/Win7 Dual Boot
Projector: Optoma HD131Xe
Receiver: Onkyo TX-NR809
Screen: Elite Spectrum Electric 125"
Media Server: NAS4Free Core 2 Quad 2.40GHz
niggenz is offline
post #3 of 8 Old 09-22-2013, 04:50 PM
tucsondave's Avatar
Is the light flickering if you look through the air vents? Sounds like your lamp may be failing. How many hours are on the lamp?
td
tucsondave is offline
post #4 of 8 Old 09-23-2013, 11:30 AM - Thread Starter
td
its the picture/light. There's no warnings about lamp life or anything, I will be home later and give that a try niggenz. Will keep you posted
post #5 of 8 Old 09-23-2013, 11:32 AM - Thread Starter
46 hours on lamp. Sorry forgot to put that lol
post #6 of 8 Old 09-23-2013, 12:18 PM
Bohanna's Avatar
Liked: 24
My guess is The lamp is breaking in and forming an arc path. This happens a lot on new lamps. Leave it on economy for about a month and then switch to full power.. If its under warranty i would call the people you bought the lamp from and ask them what to do take notes and get a case number so If it doesn't correct itself you can then send it back.
- Bohanna
Bohanna is offline
post #7 of 8 Old 09-24-2013, 05:55 PM - Thread Starter
- Bohanna
I finally took my screen and projector and set it up downstairs and just now tested it out. It appears to have stopped but it usually starts at random times during movies. Gonna watch iron man 3 on blu ray tomorrow and that should truly tell me lol thanks guys
post #8 of 8 Old 09-25-2013, 01:45 AM - Thread Starter
Well I watched iron man 3 on blu ray tonight and no flickering to report. I guess changing the blu ray players output resolution really helped lol
