For those with the HD25e, HD25-LV or HD131Xe - Question about RF Emitter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-24-2013, 07:20 AM - Thread Starter
The Outcast's Avatar
Liked: 65
For those of you owners using one of Optoma's HD series of projectors, and who use the RF emitter, where do you actually put it?
I was thinking of putting in IN the tiles I have for my dropped ceiling. Will that be a problem?
With that in mind, where do you put your RF emitter if you are using one?
Thanks in advance.
Kirby Y (aka-The Outcast)
I don't have alot of posts since I joined AVS Forums in 2004. I mainly read the information in threads as a source of research material. - quoted from The Outcast in April 2007.
The Outcast is offline
post #2 of 4 Old 09-24-2013, 04:17 PM
niggenz's Avatar
Plan on resting it on top of the projector in the ceiling mount position. Out of sight but accessible when needed.
HTPC: Intel NUC (DC53427HYE) running OpenELEC/Win7 Dual Boot
Projector: Optoma HD131Xe
Receiver: Onkyo TX-NR809
Screen: Elite Spectrum Electric 125"
Media Server: NAS4Free Core 2 Quad 2.40GHz
niggenz is offline
post #3 of 4 Old 09-26-2013, 12:55 AM
niggenz's Avatar
And it is RF, so no problem sticking it behind a wall. It just will be less accessible.
niggenz is offline
post #4 of 4 Old 09-28-2013, 08:07 AM
augiedoggy's Avatar
Or you could just use the DLP link option as well.... just saying its an option if the emitter is an issue
augiedoggy is offline
Optoma Hd25e 2800 Ansi Lumens 3d Home Theater Projector , Optoma Hd25 Lv 3d Home Theater Projector , Optoma Hd131xe Dlp Projector 3d
