What projector is good for my 127" 2.35:1 screen Throw distance 15'6" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-24-2013, 03:07 PM - Thread Starter
amb1s1's Avatar
As you can see in the picture the rear part of my room is 9'6" while the front is 20'. My first question is what is a good projector for this setup with a throw distance of 15' 6". Second question would I have issues because my rear part of the room is narrow? My budget is
2.8K and I will be using the Lumagen Radiance in-case you need that information. In the picture every square is 1 feet. You see that the projector is way behind, but I would not be able to install it there since I'm having a mini split AC install in the back.
Thanks in advance
amb1s1 is offline
post #2 of 4 Old 09-24-2013, 06:09 PM - Thread Starter
amb1s1's Avatar
I'm thinking the Epson 5020.
amb1s1 is offline
post #3 of 4 Old 09-24-2013, 10:11 PM
AV_Integrated's Avatar
Quoted: 988 Post(s)
Liked: 728
With any 2.35:1 setup, you want either an anamorphic lens on a sled ($$$) or you want a projector which has lens memory and a motorized lens so that it can easily switch between 2.35 and 1.78 modes. The poor-mans CIH setup is fine, but has sacrifices in brightness and quality which should be recognized by anyone who wants to go down that road.
I would go for the Panasonic AE8000 or the JVC DLA-RS46 both of which can be had for under $3,000 and should do what you are after. The Epson 5020, to my knowledge, does not deliver on the motorized zoom front and would not be in my list of choices.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #4 of 4 Old 09-24-2013, 10:36 PM - Thread Starter
amb1s1's Avatar
After more research, I think I heading to the dla-rs46
amb1s1 is offline
Epson 5020ub Powerlite Home Cinema 3d Front Projector , Panasonic Ptae8000u Hd Projector , Jvc Dla Rs46 Projector
