Looking for DLP with vertical lens shift that has VESA 3D jack/connection - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-02-2013, 03:57 PM - Thread Starter
curtishd's Avatar
Quoted: 166 Post(s)
Liked: 24
I am looking a for a DLP projector that can be rear shelf mounted so that usually requires lens shift and I would also like it to have a VESA 3D jack. Any ideas?
curtishd is offline
post #2 of 4 Old 10-03-2013, 11:36 AM
AV_Integrated's Avatar
Quoted: 1106 Post(s)
Liked: 803
I believe the BenQ W7000 meets your needs. Double check on the VESA port, but I thought it may have one. Otherwise, you may need to consider a JVC RS46. It's LCOS instead of DLP, but it's a great tech and has the VESA 3D port on it.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #3 of 4 Old 10-03-2013, 02:41 PM
rekbones's Avatar
Quoted: 467 Post(s)
Liked: 239
The optoma HD8300 has everything your looking for. The JVC is not known for great 3D. MSRP is $5000 but its down to around $2500 now
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
post #4 of 4 Old 10-04-2013, 07:19 AM
Liked: 803
Good info on the HD8300. Yeah, the W7000 does not have a 3D VESA port.
I will say that I've seen some DLP projectors and the RS46 from JVC and I was not able to see much, if any difference between the JVC and the DLP model. But, if looking for DLP specifically, then that Optoma model certainly fits the bill.
Benq W7000 Home Projection System , Optoma Hd8300 3d Projector
