Optoma hd65 bulb won't light - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-05-2013, 07:36 AM - Thread Starter
chevextreme03's Avatar
Hello. My optoma hd65 projector bulb won't light anymore. Everything else turns on and the bulb tries to light but never does. I replaced the bulb and still had same issue. Replaced the lamp ballast last night and still same thing. Could I have just gotten a crappy bulb? Possibly need to replace power supply? Any help would be appreciated. Thank you.
Jason
chevextreme03 is offline
post #2 of 5 Old 01-06-2014, 08:12 PM
eb3
eb3's Avatar
i have the same problem. Did you ever figure this out? Maybe an internal fuse? Im looking for it now!!!
actually, my bulb died when i barely bumped the projector (not as hard as I have before w no incident over the years). I got a new bulb and as I put in the power cored I didn't realize my hand was also depressing the peer button and so I heard a tiny noise and sure enough the new bulb was blown!
So I got a second replacement bulb today and installed it properly and then very gingerly turned on the unit. Nothin, Nada, Zilch. and the bulb looks fine!! AAaaargh. frown.gif
eb3 is offline
post #3 of 5 Old 08-21-2014, 06:24 AM
Jeremiahm's Avatar
Quoted: 22 Post(s)
Originally Posted by eb3 View Post
i have the same problem. Did you ever figure this out? Maybe an internal fuse? Im looking for it now!!!<br><br>
actually, my bulb died when i barely bumped the projector (not as hard as I have before w no incident over the years). I got a new bulb and as I put in the power cored I didn't realize my hand was also depressing the peer button and so I heard a tiny noise and sure enough the new bulb was blown!<br><br>
So I got a second replacement bulb today and installed it properly and then very gingerly turned on the unit. Nothin, Nada, Zilch. and the bulb looks fine!! AAaaargh. <img alt="frown.gif" class="bbcode_smiley" src="http://files.avsforum.com/images/smilies/frown.gif">
Sounds like what I'm going through. I'll keep an eye on this thread.
Unfortunately, all of our HD65's are probably about the same age....
Jeremiahm is offline
post #4 of 5 Old 08-21-2014, 11:35 AM
eb3
eb3's Avatar
Unhappy no internal fuse
i took mine apart and googled and googled until I finally found a post somewhere from a guy saying there is no internal fuse and that a problem like our's is probably a bad motherboard (= time to buy new projector).
that's what I did.
and even funnier (cuz if you don't laugh you may cry) I THINK they post I referred to was on this site. I think it was in reference to a guy that had a prob like this with another model Optoma...
eb3 is offline
post #5 of 5 Old 09-02-2014, 06:33 AM
dr0s's Avatar
One more thing to try: when fully closed the lamp door pushes a failsafe pressure switch. Some time back the plastic at the screwhole on mine cracked just enough that the door was no longer pressing the switch with enough pressure, and I was getting a similar symptom. To test, examine the door to make sure there isn't a broken pin, and then set the projector on a couple of books so you can access the door, turn it on, and then press the door in by hand; if the projectoir comes on and lights up, you've traced the problem to this door.
Drove me nuts until I discovered the problem. The permanent fix involved a bit of epoxy
dr0s is offline
Optoma Hd65 Plus 720p Dlp Projector With Backpack And Speakers
