Buying Advice!!! Please help... Vivitek Q5 vs Optoma ML550 vs LG PA70G - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 35 Old 11-14-2013, 01:47 PM
rgtaa's Avatar
Originally Posted by brand2 View Post
I have an acer hd6510bd that is 2.2 kg and it's still quite portable, comes with it's own portable bag. I'm not sure if you can get it cheap in the UK but newegg.com has it on sale for $630 us currency.
A person might want to check out your Bulb based PJ, if they are interested in getting a bulb PJ. The PJ's in the thread are LED PJ's , not bulb PJ's.
rgtaa is offline
post #32 of 35 Old 11-14-2013, 01:49 PM
eb3
eb3's Avatar
great suggestions. Had I not put 2 or 3 HUNDRED hours with my dad into building one of the coolest features in my house I'd be all over these ideas (It uses a a linear motor and has a cool way it locks into place, then cleans up perfectly when you raise it up, etc...).
That said, I AM going to look at where it would have to mount and see if one of these ideas will work.
eb3 is offline
post #33 of 35 Old 11-14-2013, 04:27 PM
rgtaa's Avatar
You might do better with a bulb PJ, so you could use that cool ceiling device. Something like the benq w1070, or something like that. I think these LED PJ's as more specialized , for portable, dark rooms, maybe in small to medium size rooms. The good feature with led PJ's is 30,000 hours on led and anytime quick on and off, and with the pa75u native 3d, wifi,tv tuner, which bulb PJ's don't have yet.
rgtaa is offline
post #34 of 35 Old 11-14-2013, 10:54 PM
brand2's Avatar
Yeah, I was responding more when he said that the pg80 at 2.2kg wasn't portable anymore. The acer is still pretty portable, won't fit in your pocket but it's portable. (So I would think the pg80 would still be too)
brand2 is offline
post #35 of 35 Old 05-05-2014, 09:31 AM
umpy315's Avatar
the differences between these 2 projectors are huge for me as i own both of these models as well as the aaxap300.i use these for camping and prefer the ml550 for this purpose overall.it is 2 lbs lighter than the lg ,takes 20 less watts as i run mine off 12 volt deep cycle batt using a 18 volt 65 watt car adapter.although the lg specs say 200 lumens brighter and 5 thousand more in contrast,the differences are hardly noticeable.and its almost half the size of the lg.also it is capable of audio out which sounds great.
umpy315 is offline
Optoma Ml550 Wxga 500 Led Lumens Mobile Projector , Vivitek Qumi Q5 500 Lumen Uxga Hd 720p Hdmi 3d Ready Pocket Dlp Projector With 4gb Memory Black , Lg Electronics Pa70g Micro Portable Led Projector
