INFOCUS H8606HD New DLP Full hd 3D Ready ISFccc - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 137 Old 02-17-2014, 09:06 AM
tibia's Avatar
Liked: 25
aimepijoan, if I understand you correctly you are trying to adjust RGB hue to Rec 709 with cms. Hue is set by the full width-half power bandwidth of the red, green and blue segments of the colorwheel. There is nothing you can do to change that. CMS will allow you to get some improvement regarding saturation and lightness but not hue. You can manipulate cyan, yellow and magenta hue somewhat because they are made up of mixtures of red, green and blue but since RGB are not perfect you won't be able to get CYM perfect either. If the pursuit of lumens were not such a big deal RGB color points could be made more accurate but to do so will result in lower lumens.
Best regards,
Dennis
Ftoast likes this.
Dennis
tibia is offline
post #122 of 137 Old 02-17-2014, 03:19 PM
aimepijoan's Avatar
thank you for the answer , i try to do the maximum
aimepijoan is offline
post #123 of 137 Old 03-31-2014, 12:02 PM
jaimemlg's Avatar
I have one question. I see that in the manual there are a setting to 2.35 aspecto, What made it? Compress all the image to 2.35 aspect? Put black bars an 16.9 image to get a 2.35?
jaimemlg is offline
post #124 of 137 Old 04-03-2014, 04:20 PM
swedish cook's Avatar
Thats exactly what it does, squash vertically and add black bars top and bottom, it would be nice if they added something more useful, like ability to chop the centre of a 2.35 and fill the 16:9 screen.
swedish cook is offline
post #125 of 137 Old 04-08-2014, 06:27 AM
jaimemlg's Avatar
Please, could you confirm it? Can you take some picture whit this aspect ratio enabled and disabled?
jaimemlg is offline
post #126 of 137 Old 05-04-2014, 04:32 PM
mkerdman's Avatar
I have had an Infocus IN82 installed with a Panamorph UH480 Widescreen Lens for several years and have enjoyed it a lot.
This week the IN82 has begun shutting itself down after an hour or so for some sort of thermal reason.
It may be time to swap it out rather than have it repaired.
Is the H8606D an upgrade, a lateral move or a downgrade from the Infocus IN82 in a light controlled Dedicated 2D Home Theater?
Murray Kerdman
mkerdman is offline
post #127 of 137 Old 05-05-2014, 02:36 PM - Thread Starter
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
kraine is offline
post #128 of 137 Old 05-05-2014, 03:10 PM
paris401's Avatar
Originally Posted by kraine View Post
My hundredth projector review is now online :
http://www.projection-homecinema.fr/2014/05/05/test-infocus-h8606hd-100eme-test-de-projecteurs-de-gregory/
how do expect us to read it...it aint in English...
paris401 is offline
post #129 of 137 Old 05-06-2014, 04:15 PM
Xavier1's Avatar
But your name is Paris, and its in French??!
Use google or babelfish to translate
Xavier1 is offline
post #130 of 137 Old 05-07-2014, 08:30 PM
Raoof Syed's Avatar
This is simple. Open the link, right click on french subject matter & then click on translate to English, that is all to it. I have saved the entire review on my desk top, as time permit, I will go through in detail. I bought this projector IN8606HD from best buy for $900 and it is an excellent projector. Colors are very good, 3D is amazing with  EStar America ESG601 DLP Link 3D Glasses, however, blacks are subjective. I would rate it, as more than adequate.
Desperately trying to get some calibration settings, such as contrast, color, brightness, sharpness, brilliant color etc, etc. So far no luck, just going with default settings.
Raoof
Raoof Syed is offline
post #131 of 137 Old 05-15-2014, 11:18 AM
willscam's Avatar
I'm contemplating supplementing my current projector, a JVC 4810, with this PJ. I would use the INFOCUS projector for 3D content, console gaming, and possibly casual netflix or cable network viewing. I would reserve my JVC primarily for high quality content from my bluray player and media streamer.
My requirements for a second PJ are 1) that it's a 1080p DLP, for zero ghosting on 3D and low lag with gaming; 2) it will accomodate my throw distance of 13 ft (115" 2.35 aspect ratio 1.1 gain screen); 3) that it has a VESA connector so that I can use my MonsterVision RF 3D glasses and 4) that it's cheap (<$1000).
In my research so far, this is the first projector that fills all of my requirements (I was looking at the Sharp Z30000, but they're no longer available at a price I'm willing to pay). I will follow this thread to get a grasp on owners' experiences with this projector. My room is darkly painted and light controlled, so one concern I have is the low contrast and black levels of this PJ, but with the type of content I intend to use it for, I hope this won't be much of an issue. Thanks to everyone that contributes to this thread! smile.gif
"Trying is the first step towards failure" - Homer Simpson
willscam is offline
post #132 of 137 Old 05-15-2014, 05:54 PM
curtishd's Avatar
Quoted: 152 Post(s)
Any lens shift? Whats the off set?
curtishd is online now
post #133 of 137 Old 05-15-2014, 06:05 PM
willscam's Avatar
No lens shift. Offset is 10. So, ability to properly place the pj in the room is important. It does have a throw ratio of 1.39 -2.09 and a zoom ratio of 1.5 which helps.
willscam is offline
post #134 of 137 Old 08-07-2014, 06:17 PM
Tank6585's Avatar
Same boat, is this an upgrade over the IN82? Every other DLP projector under $3000 has crap focus uniformity.
Tank6585 is offline
post #135 of 137 Old 08-17-2014, 07:48 AM
Thinker's Avatar
Originally Posted by tibia View Post
Hi martinzmc,<br><br>
What you are seeing is what we call a blemish. There is really only one blemish but you see reflections of two because the light entering the DMD is at a 45 degree angle. You are seeing the blemish reflected from the DMD window exterior surface then slightly offset reflected again by the interior window surface. Blemishes are only visible in a totally black image or very close to total black. That is, all mirrors tilted toward the light engines' dump zone. Ordinarily you focus on the plane of mirrors which is slightly farther away from the lens than the window's interior surface. Because the window glass has some depth to it you can never get ideal focus of both reflections at the same focus setting.<br><br>
The TI DMD quality specification says that a blemish is allowed if it is no more than one inch diameter or length when viewed with normal brightness and contrast settings on a 1.0 gain screen, 60" diagonal, from a distance of two meters. Blemishes are rarely visible if there is even the slightest amount of light reflected from the mirror array to the lens. TI allows that no image greater than Gray 10 be used to evaluate blemishes. That is 10 out of a range of 0 to 255. DMD technology is linear regarding signal input vs image brightness. In other words it is natively linear gamma. Projectors and other display devices use gamma settings of about 2.1 to 2.6. The standard is 2.21. This means the 2.2 gamma video signal will need be well above bit level 10 in order to be equal to linear gamma's bit level 10. This is why you don't see blemishes in normal projector operation.<br><br>
Best regards,<br>
Dennis
tibia, so is the "blemish" what I am seeing on this projector that looks like two lens-flare circles in one quadrant of the screen on very dimly lit scenes?
Thinker is offline
post #136 of 137 Old 08-17-2014, 04:41 PM
tibia's Avatar
Liked: 25
Thinker,
A 'blemish" is most likely what you are seeing. It is either that or something in the projection lens. Try adjusting focus. If the blemish moves as you turn the focus ring it is a lens issue. A DMD blemish will remain stationary and change its size as you adjust focus. In either case it is something you can't fix.
Best regards,
Dennis
Dennis
tibia is offline
post #137 of 137 Old 08-20-2015, 04:08 PM
tokbandit's Avatar
Quoted: 12 Post(s)
I know this is a dead thread...and I did a lot of research before purchasing this...as it fit all my needs except for 2x colorwheel speed, only one user setting, and ISF Day and Night settings being locked out....well my question is to Dennis or any other owner of this projector...is the Video AGC, Video Saturation, Video Tint supposed to be locked out as well? as I cannot adjust them at all...are they not associated with the HDMI connection? I really would like to unlock the ISF Day and Night but seems only a technician can do that but be nice if there was a way to do it yourself...hate they advertise but not let it be an option to the user without paying more money for a professional to do it...
with that said...I am coming from the Infocus 4805...I have owned it since 2005 and have used it for everything...daily watching TV, Movies, and Video games...first bulb lasted at least 6 years of heavy usage..and had to replace the colorwheel as it exploded on me...its been great to me...but I felt I need to at least upgrade to 1080p to get with the times...and since DLP projectors are fairly cheap these days and I upgraded my sound system to MartinLogans I felt like I need a new projector...I am happy with the quality of the 8606 but the lack of calibration options and rainbows are annoying...I never seen rainbows with the 4805 given that it was a 4x speed colorwheel but the 8606 from what I understand is 2x at 60/30, 4x at 24, and 6x at 3D but even with 24fps enabled on my Sony Bluray or using the XBOX One...the rainbows were stupid crazy when I watched Aliens 4...then I watched it on my 4805 and no rainbows...I know the 8606 is much brighter and that happens with a combination 2x speed colorwheel..so is my unit defective so the 4x speed doesnt work at 24fps?
After the shock of rainbow city was over and I tried multiple Blurays and watching TV...I think I have adjusted some what to them...as I dont see them as often but I also learn not to move my head and stare at one spot and try not to do rapid eye movements to looking around...so to anyone also with time will the Rainbows kinda be over looked or should I return this to Amazon and wait for a good LCD projector? I kind was looking at the BenQ HC1200 because of the long throw...kinda like the quiet 8606 after my 4805 JET Plane...heard the HC1200 has rainbows too but is it any less than the Infocus? does it have a 6x speed colorwheel like the BenQ 1070 and 1075? ...what about the blacks? I heard they're little grey...how are they compared to the 8606 which I like even though it is hard to make out the midtone blacks..
anyone?
tokbandit is offline
Infocus , In Focus
