The Peal vs something new - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-14-2013, 12:12 PM - Thread Starter
terrible_buddhis's Avatar
There is a guy locally selling a VW50 for about $400 with a fairly new bulb. MOST of my watching is 2d, sports, and playing movies/video games on my PS3. Should I be looking at something newer? Or would this fit the bill? Oh, 92" screen.
terrible_buddhis is offline
post #2 of 10 Old 10-14-2013, 12:22 PM
Verge2's Avatar
Quoted: 782 Post(s)
Liked: 204
There were grumbling a that lcos chips wore out and lost contrast over thier lifetime.
If this is true, nah.
If this is false, offer him 350
Verge2 is offline
post #3 of 10 Old 10-14-2013, 12:32 PM
Bohanna's Avatar
Liked: 24
Find out how many total hours on the projector. If its over say 3000 hours the blue LCD panel is starting to wear out .
Bohanna
Bohanna is offline
post #4 of 10 Old 10-14-2013, 12:36 PM - Thread Starter
about 2600...should probably pass huh?
post #5 of 10 Old 10-14-2013, 01:13 PM - Thread Starter
I think the 8700UB fits the bill if I can find a refurbed.
post #6 of 10 Old 10-14-2013, 01:38 PM
Bohanna's Avatar
Liked: 24
Right on the Border I think. If it were ME considering you plan on using it for gaming I would look into the newer LED projectors. They will work fine for a 92 inch screen. I have a Pa70 I got at Frys onsale for 499.00 delivered and it looks fine> I don't use it as much as I thought I would but for gaming or everyday use its perfect and you don't worry about a lamp failing and costing you a couple of hundred bucks to replace it. The same applies to the epson as far as lamps go. Bohanna
Bohanna is offline
post #7 of 10 Old 10-14-2013, 01:58 PM
Verge2's Avatar
Quoted: 782 Post(s)
Liked: 204
It's not
Bohanna
It's not an lcd, and it's light years better than a cheap ultraportable.
Verge2 is offline
post #8 of 10 Old 10-14-2013, 02:23 PM
Bohanna's Avatar
Liked: 24
Originally Posted by Verge2 View Post
It's not
could you be a little more specific? Your answer doesn't make any sense. - Bohanna
Bohanna is offline
post #9 of 10 Old 10-14-2013, 04:04 PM
Verge2's Avatar
Quoted: 782 Post(s)
Liked: 204
1 it's sxrd, it's not lcd. It's lcos.
2 it has better contrast resolution calibration features, it's light years better than a cheap lg.
Verge2 is offline
post #10 of 10 Old 10-14-2013, 06:28 PM
Bohanna's Avatar
Liked: 24
its Still LCD technology and the Blue screen will eventually fail. They say they use an "inorganic alignment layer" but the Panels are still ORGANIC. The picture will be better than the LGPA70 as long as the panel lasts but if the guy plans on using it for any length of time he could be buying a headache!
Bohanna
Bohanna is offline
