Projector or TV ? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 10-18-2013, 03:03 PM
PENDRAG0ON's Avatar
Liked: 574
Originally Posted by coderguy View Post
10% to 50%, a good average is 20% to 35% is the norm at 1000 hours.
Yikes, that puts the half life of the bulb at under 2000 hours. Luckily for me LG are releasing a 1080p LED projector soon for a reasonable price. I'm keeping a close eye on Amazon and the thread for it.
PSN - Pendragoongp
NNID - Pendragoon
PENDRAG0ON is offline
Old 10-18-2013, 03:11 PM
FilmReverie's Avatar
Quoted: 14 Post(s)
Liked: 74
Remember we do not see light in a linear manner. We are unlikely to be able to notice a 10% change in light for example.
FilmReverie is offline
Old 10-18-2013, 03:27 PM
Crabalocker's Avatar
Quoted: 182 Post(s)
Liked: 122
^ yep, the eyes are a neat invention!
Crabalocker is offline
Old 10-18-2013, 04:53 PM
DLPProjectorfan's Avatar
Quoted: 21 Post(s)
Liked: 45
Do you use that 70 inch TV in the living room or theater room ?
Perhaps if you can hold out until next year some more 1080p led projectors would be coming out on the market.
DLPProjectorfan is offline
Old 10-18-2013, 05:03 PM
PENDRAG0ON's Avatar
Liked: 574
Family room with lots of light. I was going to convert a spare bedroom into a dedicated theater room next year. I like to start my research early and plan things out. biggrin.gif
PSN - Pendragoongp
NNID - Pendragoon
Old 10-19-2013, 01:05 AM
coderguy's Avatar
Quoted: 303 Post(s)
Liked: 271
The bulb does not dim linearly, it dims the fastest in the first 1000 hours, then after that point it dims much slower. For instance a bulb that dims 35% in the first 1000 hours may only dim 15% in the next 1000.
Access HERE from this thread
coderguy is online now
Old 10-19-2013, 06:10 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
If the projector is sized correctly for the screen size, gain and throw to start with, normal light loss though aging is not a problem. People tend to buy over sized > 120" screens and a projector that can just about light up that size with a new lamp. Then 500 hours later they are pissed when there isn't enough light.. The manufacture may say image from xx - xxx but that is just how big the lens will make the image not that the projector can actually light it up to a sufficient level to be watchable.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
