Epson 5020 TEch problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-26-2013, 07:35 AM - Thread Starter
nadav1983's Avatar
Hey guys,
I bought the epson 5020 not long ago, and watched about 6 or 7 movies on it.
Then I havent watched it for about 2 or 3 weeks and when i tried watching a movie today it turned off and the lamp and temp lights went red.
the filter is clean so that is not the case. any ideas what might happen and what should i do?
the thing is I bought the projector from the US and I live in israel so if I can spare shipping it back it would be great but...you know better.
waiting for you guys to help.
nadav1983 is offline
post #2 of 5 Old 10-26-2013, 02:09 PM
programmergeek's Avatar
I would unplug it for a bit plug it back in and see if it happens again. Once in a while a reset clears up some issues.
programmergeek is offline
post #3 of 5 Old 10-26-2013, 07:22 PM
42Plasmaman's Avatar
Quoted: 20 Post(s)
Liked: 37
2 things you can do.
1. Take the lamp out and then reseat it.
2. If this happens again, let it power off by itself. May take 10 minutes then turn the main power switch off on the rear.
Wait a minute and turn back on.
*These 2 items are what Epson support will recommend if you call/request support.
If that doesn't work, then request a bulb replacement if possible because that's the next step.
This issue has plauged the 50xx line since the release. I've had no issues since having the bulb replaced under warranty over a year ago.
Prior to that, this issue would happen about every 5th to 10th power up.
2016
42Plasmaman is offline
post #4 of 5 Old 10-26-2013, 11:37 PM - Thread Starter
nadav1983's Avatar
Well first thing thank you very very much for the quick reply. you guys are amazing.
secondly when you say reset its via the menu bar? or is there a reset button on the device?
also I understand this happend to a lot of people? is it something I did wrong or is it a common prob?
Thanks again guys.
post #5 of 5 Old 10-27-2013, 02:36 PM
Quoted: 20 Post(s)
Liked: 37
The power switch on the rear of the projector.
It cuts power to the projector,
2016
Epson 5020ube Powerlite Home Cinema 3d Wireless Front Projector , Epson 5020ub Powerlite Home Cinema 3d Front Projector
