picture issues benq w1070 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-26-2013, 04:23 PM - Thread Starter
dutchy84's Avatar
I just bought the benq w1070 for my living room. Everything went up great and then i turned on the pj...the top of the image is level and the rest is slanted to the left side toward the top...ive been fidgeting around for the better part of 2 hours now with no luck....any suggestions? 20131026_161936.jpg 1069k .jpg file
20131026_160925.jpg 1063k .jpg file
I tried to search the issue but in my rather frustrated frane of mind i decided to post instead. Thanks
ID:	72897   Click image for larger version
dutchy84 is offline
post #2 of 4 Old 10-26-2013, 09:49 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
your projector is not square with the screen.
rotate it left then right you will see how it alters the image..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #3 of 4 Old 11-05-2013, 08:52 AM
JNasty's Avatar
I just got mine. Were you able to correct the issue? I'm having the same problem. Moving my projector left and right doesn't fix the issue.
JNasty is offline
post #4 of 4 Old 11-05-2013, 11:28 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
Welcome to the forum. I would suggest that you post these questions in the regular thread. No need to start a new thread with every question.
The projector is not set up correctly. You don't say how it is mounted but it is not even with the screen. That is the reason for the test pattern. Try moving the projector slightly on each side from front to back. You may also want to measure the distance from the projector on each side. Being off by a slight amount will cause this issue.
rwestley is online now
Benq W1070 3d Ready Dlp Projector 1080p Hdtv
