Short Throw Replacement for W6000? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-27-2013, 08:53 AM - Thread Starter
cgott42's Avatar
Quoted: 133 Post(s)
I currently have a W6000 and love it, however I'm thinking of redoing my HT to allow for a bigger screen (12' width 2.40 Aspect Ratio) and thus moving the screen to the long wall - meaning that the projector would be about 10' from the screen. The min. distance that I've found for a comparable proj is about 14'
Any ideas?
I'm not into 3D, and have a dedicate Bat Cave with no ambient light
Was hoping for something in the same price range (used is fine/preferred)
cgott42 is offline
post #2 of 6 Old 10-27-2013, 12:07 PM
AnthonyJS02's Avatar
Just chiming it because im about to purchase one, but the Benq 1080st is supposed to be pretty good not sure if it will accommodate your screen size.
AnthonyJS02 is offline
post #3 of 6 Old 10-28-2013, 09:45 AM - Thread Starter
cgott42's Avatar
Quoted: 133 Post(s)
thanks - though it seems the contrast ratio isn't on par with the W6000
cgott42 is offline
post #4 of 6 Old 10-28-2013, 02:26 PM
AV_Integrated's Avatar
Quoted: 983 Post(s)
Liked: 724
How do you plan on dealing with the switch from anamorphic widescreen to 1.78 material? Since all BDs and HDTV is 16:9 (1.78) format, you will either need a projector with lens memory and the appropriate zoom range (which you don't have) or you will need an anamorphic lens on some sort of sliding sled and a projector which properly handles the necessary 2.35 zoom/stretch to make this work.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #5 of 6 Old 10-28-2013, 02:31 PM - Thread Starter
cgott42's Avatar
Quoted: 133 Post(s)
I don't get to watch too many 2.40 AR films - so when I do I manually zoom.
cgott42 is offline
post #6 of 6 Old 10-28-2013, 06:44 PM
dougri's Avatar
Quoted: 45 Post(s)
Liked: 52
.83 throw ratio with good contrast and sharpness is tough, even used... You are looking st the w1080st without a DI, a used Infocus SP8604 with the fixed short throw lens option( if you can find one in north america), or used Runco, DPI, Sim2, etc., with a short throw lens, which is likely out of budget even used. Another option would be a standard projector that allows vertical mounting and s first surface mirror... Not sure such a thing exists for home theater in this price range though.
dougri is offline
Benq W6000 1080p Dlp Projector , Benq W1080st 1080p 3d Short Throw Dlp Home Theater Projector
