Is Something Wrong with My W1070's White and Black Levels? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 10-30-2013, 06:24 PM - Thread Starter
Tangled Cable's Avatar
Quoted: 115 Post(s)
Liked: 36
When I tried to calibrate my w1070 with the Disney WOW disc I noticed that it would not properly display the contrast (white level) and brightness (black level) test patterns. There were test bars that were supposed to be visible for each pattern but no matter where I set my black and white levels, most of the bars would not be visible, even though they were supposed to be.
I still like the image this projector throws and so I hoped it was just an issue with the test patterns themselves.
But I just got the Spears and Munsil calibration disc and I'm seeing the exact same thing ... Serious white and black crush, no matter what settings I choose.
What does this mean? Is there something wrong with my projector?
Tangled Cable is offline
post #2 of 11 Old 10-30-2013, 07:48 PM
FilmReverie's Avatar
Quoted: 14 Post(s)
Liked: 74
Could you run through all the settings your projector is set at.
FilmReverie is offline
post #3 of 11 Old 10-30-2013, 09:48 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
I think this may help
http://www.avsforum.com/t/1468725/issue-with-disney-wow-calib-disc/0_100
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #4 of 11 Old 10-31-2013, 01:21 AM
kwk2293's Avatar
Quoted: 46 Post(s)
Liked: 26
Chech hdmi setting should be on pc setting. Also on my w7000.blueray player must be outputting rgb colorspace to do wtw or btb
kwk2293 is offline
post #5 of 11 Old 10-31-2013, 05:21 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Actually if you plan on send the output of a STB or anything else, you will need to have them all set to RGB. Most folks use 4:2:2 as some displays do not do RGB correctly and some devices will not output RGB. For more info on the difference and what to use do a search for Color Space in the calibration forum and look for posts by Doug Blackburn as he explains it very well...
This thread has to do with a TV but the same sort of problem and it will help explain why you are having issues.
http://www.avsforum.com/t/1495362/why-wont-my-blu-ray-player-display-black-correctly/0_100#post_23852756
Doug
post #6 of 11 Old 10-31-2013, 09:18 PM
kwk2293's Avatar
Quoted: 46 Post(s)
Liked: 26
I use lumagene 3d mini to convert to rgb to send to w7000
kwk2293 is offline
post #7 of 11 Old 11-01-2013, 01:19 PM - Thread Starter
Quoted: 115 Post(s)
Liked: 36
Thank you all for weighing in!
@FilmReverie
I tried to include what I see as the relevant settings below ... Let me know if there are other specific settings you think I should list.
@airscapes
Thanks for the link! The key post in that first thread seems to be:
In the menus for the BenQ W1070 there is an HDMI setting you need to change to allow WTW and BTB content to pass. I can't recall the name of it off-hand,but if you search for it and change it, then you'll see the bars. I believe it's on Auto by default.
Unfortunately there is no HDMI setting that I can find on my projector that does anything of the sort, apart from the "HDMI Format" settings listed below, which change nothing that I can see.
@kwk
Thanks for the suggestions. Tried those but they didn't make any difference .....
In case I haven't explained it clearly, I took some screenshots to illustrate the problem. This is how the pattern is supposed to look. All the bars are clearly visible.
This is what I actually see with my projector. Only the first three or four bars are (barely) visible and the rest are completely washed out.
Strangely, when I go to my Oppo's setup screen, which is a transparent overlay, I can suddenly see all the bars from the calibration screen beneath it perfectly ...?
Here are all the settings I've tried so far:
Under "HDMI Format" in my projector's menu:
Switched from "PC signal" to "Video Signal" to "Auto."
Made no difference.
Under "HDMI Options Color Space" in my Oppo blu-ray player's menu:
Switched from "RGB Video Level" to "RGB PC Level" to "YCbCr 4:4:4:" to "YCbCr 4:2:2:"
Made no difference.
Any other settings you think I should try? Those seem to be the only ones directly related to this issue that I can see. I have of course tried "contrast" and "brightness" settings as well, but no matter what I do, only the first three or four bars are visible. It is almost as if the "contrast" setting is disabled. When I'm actually watching a movie, I can adjust contrast and clearly see the changes that are being made, so I'm not sure if the crushed white levels I'm seeing with the calibration screen are actually affecting the overall image quality ... ?
By the way, there are no "whiter than white" or "blacker than black" style settings for either my oppo player or the w1070. The w1070 does have "Black IRE 0" option but it is grayed out and I can't use it under any setting ...
Here is another thread from someone experiencing a somewhat similar issue ...
http://www.avsforum.com/t/1463374/benq-w1070-clipping-black-white-and-color-levels
Anything else I should try? Ideas as to what this might mean?
post #8 of 11 Old 11-01-2013, 02:01 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Try matching them, project RGB PC and BR RGB video, if no then RGB PC. note make sure you attempt to adjust brightness and then contrast with each setting.
Doug
post #9 of 11 Old 11-01-2013, 11:04 PM
kwk2293's Avatar
Quoted: 46 Post(s)
Liked: 26
@FilmReverie
@airscapes
@kwk
Made no difference.
Made no difference.
Have you tried hdmi. Pc level then on opposelect rgb pc level at same time
kwk2293 is offline
post #10 of 11 Old 11-02-2013, 04:45 PM - Thread Starter
Quoted: 115 Post(s)
Liked: 36
Tried both of those combinations and still couldn't get the numbered bars to show up. I can see the first three or four but no more than that ...
post #11 of 11 Old 11-02-2013, 07:49 PM
kwk2293's Avatar
Quoted: 46 Post(s)
Liked: 26
Post this question on w1070 forum see if any one with this projector can confirm this projector will do wtw and btb if they can my be time to give benq a call
kwk2293 is offline
Benq W1070 3d Ready Dlp Projector 1080p Hdtv
