DLP projectors under 3 grand with best blacks? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-04-2013, 09:35 AM - Thread Starter
eric.exe's Avatar
Quoted: 16 Post(s)
What DLP projectors under 3 grand have the very darkest, inkiest, richest, black levels? The kind where you can barely see the where the screen ends and where the wall starts. It will be used in light controlled room.
eric.exe is offline
post #2 of 7 Old 11-04-2013, 09:37 AM
AV_Integrated's Avatar
Quoted: 981 Post(s)
Liked: 722
Yes, I wonder that myself.
IME none touch JVC (LCoS), and this is a failing on the part of TI and their manufacturers. Or, perhaps it is the failing of consumers to want to buy more quality.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #3 of 7 Old 11-06-2013, 03:54 PM - Thread Starter
eric.exe's Avatar
Quoted: 16 Post(s)
Anyone care to chime in?
eric.exe is offline
post #4 of 7 Old 11-06-2013, 04:07 PM
Seegs108's Avatar
Quoted: 4217 Post(s)
Liked: 2093
You're best bet is a Sharp XV-Z30000.
Seegs108 is online now
post #5 of 7 Old 11-06-2013, 04:11 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
If you want A DLP with good blacks (not a dynamic iris) then you need to look at high end models or used high end like Planar, Runco, Sim2 and others in the 2008-2012 Over $5000 original MSRP or new stuff in the category. I recently purchased a use Planar PD8150 (2008-2010) same design as the current Runco LS5 that I am very happy with.. inky black bars ..not really, but a perfectly focused edge to edge, super sharp, color accurate, superb shadow detail, quiet operations and a punchy picture with lens shift, I wouldn't trade it for anything current under $4000. I paid less the $2000 and yes it only puts out 1000 lumen but on a 110" HP 2.8 on eco I get 20fl as measured at my seat with a colorimeter. I had a new sharp Z30K and with the iris on it was blacker than what i have but that was the least important of the traits.. I will take a pin sharp focus with fantastic ansi contrast and not so great black bars any day (hate the iris). If you want new, check out coderguys thread, as he has personally reviewed many of the newer projectors.
Hey Dylan.. did you buy a 30K?
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #6 of 7 Old 11-06-2013, 09:30 PM
Seegs108's Avatar
Liked: 2093
It's one of the last 1080p DLP units I want to check out. I'm sure it's no PD8150, but it seems to be one of the best performing 2D and 3D units under $3000.
post #7 of 7 Old 11-07-2013, 06:25 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
I never tired the 3D, but I am thinking that is it's strongest asset unless the copy I got was not up to par.
Doug
Sharp Xv Z30000 Dlp
