Epson 8350 vs. BenQ W1070 Opinions Needed ASAP - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Epson 8350 VS BenQ W1070
Epson ($550) 3 42.86%
BenQ ($911) 4 57.14%
Voters: 7. You may not vote on this poll
post #1 of 6 Old 11-05-2013, 04:58 PM - Thread Starter
davi8915's Avatar
I know this topic has been beaten into the ground, and I have done a ton of research on both - however I am counting on you all to help me make my final decision! I plan on using the PJ mostly for sports viewing, movies and FIFA/COD on my Xbox One in a few short weeks. Viewing area will be pretty light controlled, with a throw distance of approximately 10'. 3D is of no real importance to me, my Denon 1910 isn`t capable of 3D passthrough anyway. Here is where it gets fun... I have the opportunity to buy a newly refurbished Epson 8350 off of my buddy for $550 - it has just 18 hours on the bulb since he took delivery. My other option is the W1070 which I currently have ordered through my local BB for $911 after tax. I need to make my decision by tomorrow morning so please let your opinions rain down. Thanks!
-Trent
davi8915 is offline
post #2 of 6 Old 11-05-2013, 08:05 PM
vidkidd's Avatar
Liked: 24
If frame lag is a concern for your gaming, then the BenQ 1070/1080 series. I've only recently worked with a Epson 2030 and it's ability to push a clean 1080p pixel map was pathetic at best. The 8350 may be a different beast all together, but, it still has a high frame lag time.
vidkidd is offline
post #3 of 6 Old 11-06-2013, 12:26 AM
vidkidd's Avatar
Liked: 24
Epson's image representation is muddy at best and IMO looks like a lower resolution image that has been scaled to a higher resolution image on the display surface. Perhaps they used a 720P display engine and output to a 1080P display surface. Then their fast image processing, which is definitely lower resolution is a direct path off the GPU without scaling. Image clarity on the Sanyo Z3 is close to the BenQ clarity with some minor panel misalignment issues at various locations in the image.
BenQ 1080ST
Epson 2030 "FINE" image processing mode. "FINE" = major frame lag for gaming - Still no match for DLP.
Epson 2030 "FAST" image processing mode. Fast needs to be replace with another 4 letter word.
vidkidd is offline
post #4 of 6 Old 11-06-2013, 03:09 PM
rekbones's Avatar
Quoted: 408 Post(s)
Liked: 196
If you were buying either one of these projectors for about the same price I would recommend the DLP over the Epson. But for half of what the 8350 goes for now from a known source that you can trust I would buy the Epson. As far as I know there is no lag on the 8350, don't compare it to the 2030 as they are completely different projectors.
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is online now
post #5 of 6 Old 11-06-2013, 03:32 PM
42Plasmaman's Avatar
Quoted: 20 Post(s)
Liked: 37
This is correct.
Keep in mind that Epson has great customer service and a 2 year warranty.
The generous lens shift is also nice for projector placement.
Only thing to check is convergence on any 3LCD/LCOS projector when you set it up.
They will never be as sharp as DLP but if you're not sitting 2 feet from the screen, convergence being a pixel off is not noticeable in regards to sharpness.
Also, with fast game play, your eyes dart across the screen a lot, which makes rainbows(RBE) appear more often on a DLP.
2016
42Plasmaman is offline
post #6 of 6 Old 11-06-2013, 08:01 PM
acex008's Avatar
Quoted: 16 Post(s)
And if you don't buy that Epson from you buddy, PM me his contact info! I'll buy the same day he contacts me...
acex008 is offline
Epson Powerlite Home Cinema 8350 , Benq W1070 3d Ready Dlp Projector 1080p Hdtv , Benq W1080st 1080p 3d Short Throw Dlp Home Theater Projector , Epson Powerlite Home Cinema 2030 3lcd Projector
