POLL: Benq W1070/1080ST Rattling Fan Noise - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: My projector has a rattling fan
YES - my BenQ w1070/1080st PRODUCES a rattling noise 21 84.00%
NO - my BenQ w1070/1080st fan generates a smooth and consistent noise 4 16.00%
Voters: 25. You may not vote on this poll
post #1 of 12 Old 11-07-2013, 09:40 AM - Thread Starter
vidkidd's Avatar
Liked: 24
Does your Benq W1070/1080ST projector produce a fan rattling noise?
If you have one of these projectors, answer the POLL and let BenQ know! It would be helpful to report WHAT device you have and WHEN the issue started (in operational hours) and how many projectors you have been through.
Overview: I just received a NEW 1080ST from amazon that has a failing cooling fan that rattles, generating excess low-decibel rattling noise, with 0 operational hours on the device. The fan issue clearly sounds like a poorly manufactured fan that should have failed the manufacturer's and BenQ's Quality Assurance.
After speaking with BenQ Engineering support regarding the W1070 and the 1080ST, their issue tracking system does NOT show there is a problem with the cooling fans on these projectors.
Thx!
Vidkidd
rattling.MOV.zip 1077k .zip file
vidkidd is offline
post #2 of 12 Old 11-07-2013, 10:12 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
I have had no problem with this noise. I will say that the fan is louder than other projectors that I have owned.
rwestley is offline
post #3 of 12 Old 11-13-2013, 10:13 AM
mustafa811's Avatar
yes after like 300 hour fans started to rattle and produce irregular noise .. search youtube for w1070 irregular noise
any idea of how to fix ?!!! wouldn't like the fan to fail and the device to overheat and die
i am thinking of blowing air inside or dissassembling cleaning fan then assembling again
mustafa811 is offline
post #4 of 12 Old 11-13-2013, 10:33 AM
regalman82's Avatar
Mine has close to 1500 hours on it. Got it april this year and no noise at all just the normal fan noise. My seating position is directly under so you would think i would hear it.
Blake
regalman82 is offline
post #5 of 12 Old 11-13-2013, 06:58 PM - Thread Starter
vidkidd's Avatar
Liked: 24
My replacement 1080ST showed up from Amazon yesterday and it is not making the noise. It was manufactured in July of 2013 and shipped with Firmware 1.02 as well as the old / smaller / non-backlit remote control that was sent back to Amazon and eventually BenQ. Upgrading to firmware 1.03 added functionality to support the backlit remote control. Lets see how many hours it lasts before the rattling / hard drive crunching / chirping noise starts up.
vidkidd is offline
post #6 of 12 Old 11-13-2013, 10:24 PM
felonyr301's Avatar
I did not vote since I only have 22 hours on my W1080ST and not even a week in my house but I do not hear what you would call rattling fan noise. My was manufactured in July 2013 and was ordered from Amazon. I received firmware 1.03 and the the back-lit remote control to be honest I did not know they switched remote controls was just hoping I got a good working version with at least 1.03 firmware already installed.
Waiting a bit before my 30 days and ordering the 4 year protection plan from Squaretrade that pop up on Amazon.
Xbox Live Gamertag: FELONY 301
PSN ID: FELONY--301
No problem adding people...
felonyr301 is offline
post #7 of 12 Old 11-17-2013, 05:46 AM
Skylinestar's Avatar
Quoted: 1046 Post(s)
Liked: 182
Is this a batch problem?
Skylinestar is online now
post #8 of 12 Old 11-17-2013, 02:58 PM
hotjt133's Avatar
Quoted: 21 Post(s)
Liked: 30
How can I retract my poll? My projector no longer produces rattling sound. In both 3D and 2D, Smart Eco, it is just smooth fan noise. I'm on 5xx hours. It developed rattling at around 70, but now it seems to have gone, and I don't remember since when.
hotjt133 is offline
post #9 of 12 Old 11-18-2013, 05:28 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
I would suggest that people who reply to this poll also list their firmware version. I am wondering if a firmware change can fix the problem.
rwestley is offline
post #10 of 12 Old 11-18-2013, 02:59 PM
hotjt133's Avatar
Quoted: 21 Post(s)
Liked: 30
A good point. Mine comes with 1.05, and have changed to 1.06. I can't contribute the disappearance of cricket to the firmware upgrade, but worth a thought.
hotjt133 is offline
post #11 of 12 Old 11-18-2013, 03:05 PM
petesvt's Avatar
Quoted: 13 Post(s)
Mine is on 1.06 FW and no fan noise, 528 hrs on the projector.
petesvt is offline
post #12 of 12 Old 05-23-2016, 02:42 PM
falconium's Avatar
Benq W1070+, 130 hours, 1.05 FW, fan noise
How to upgrade the firmware? Reliable source? I barely believe though a FW upgrade would solve a mechanical issue, as whatever the fan speed is, it rattles anyway.
falconium is offline
Benq W1070 3d Ready Dlp Projector 1080p Hdtv , Benq W1080st 1080p 3d Short Throw Dlp Home Theater Projector
