W1080st or w1070 in 12x12 room? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-10-2013, 07:57 PM - Thread Starter
f430's Avatar
Is it better to have the projector right over my head - w1070 at 10' - 11'
or have the projector about 1/2 way between me and the screen w1080st at 5' - 6' ?
BenQ W1070 - DENON AVR-E400 7.1 - SLS Q-Line Gold - Hsu VTF-2 MK4
Watch the progress http://www.avsforum.com/t/1517374/budget-build
f430 is offline
post #2 of 3 Old 11-10-2013, 08:49 PM
Prime316's Avatar
Quoted: 179 Post(s)
Liked: 204
My choice would be overhead. I run my W1070 right overhead with a 9 foot ceiling. It hangs down about 10 inches so it's about 8 feet up and I don't have any problem with noise or anything while watching movies. If it were out in front of me, i'd pay attention to it while I'm watching movies, but that's just me.
If you aren't limited by space with the screen size you need, I don't really see a need to buy a short throw projector. I guess a better question would the W1070 throw the size picture you want in your given space. If so, I would go that route.
The W1070 will throw at least a 120" picture in the size room you have.
Projector: Benq W1070 1080p 2D/3D
AVR: Denon X2200W
Mains: Klipsch RF-62ii x 2
Center: Klipsch RC-62ii
Surrounds: Klipsch RS-42ii x 2
Subs: Dual Hsu VTF-15H's
Prime316 is offline
post #3 of 3 Old 11-11-2013, 07:07 AM - Thread Starter
f430's Avatar
Thank you
My concern was noise right above the seats, but like you, I did not want to see the projector hanging in front of me either. Looks like I've decided thank you smile.gif
Edit: my screen is going to be around 110" so I should be good to go
f430 is offline
Benq W1080st 1080p 3d Short Throw Dlp Home Theater Projector , Benq W1070 3d Ready Dlp Projector 1080p Hdtv
