Is a projector right for me? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-12-2013, 07:36 PM - Thread Starter
duke06's Avatar
Hi Guys,
I am trying to decide if a projector would make sense for me. My main TV room is an upstairs loft that has some ambient light. If I want to darken the room I would say I can get it down to about a 8.5/10 with 10/10 being pitch black, personally I don't like always sitting in a dark room so I am curious if a projector will look terrible if say I had a lamp on and the room was then like a 5/10 in darkness. I realize this may be vague but it is the best way I know how to demonstrate what I mean.
For reference I am looking to spend under $1000 on the projector.
Do most people use their projector for 100% of their TV watching? I just feel like sitting in a dark room all the time even on nice sunny days may get tiresome.
duke06 is offline
post #2 of 3 Old 11-13-2013, 02:40 PM
rekbones's Avatar
Quoted: 505 Post(s)
Liked: 257
I guess the best way to look at it is to go into the room your considering putting a projector in, turn on the lights you would like on and look at the wall you want to project an image on. If the wall is white ( hang a piece of white cloth or paper if it isn't) that is the darkest black level you will see from the projector. Most people don't use a projector for all of their TV viewing, I do but I am the exception ( although still not 100% as I do have three other TV's). Projectors with Bulbs can't be turned on and off at will without damaging the bulb and decreasing its life. I like dark and rainy days so I won't feel guilty hold up in my man cave watching movies. My first projector I used as my main TV and needed a new bulb at $400 a pop every six months, I quickly replaced it with a TV. There are always options and you have to look at the pros & cons to decide.
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is online now
post #3 of 3 Old 11-14-2013, 09:48 AM
AV_Integrated's Avatar
Quoted: 1148 Post(s)
Liked: 825
Certainly a projector will work, but you want to control light no matter what.
Light control comes in many forms. The first thing people think of is closing the shades. This makes sense, but it really isn't the first thing.
The first thing should be darkening the room with a coat of paint which is dark. The darker the better. Dark paint sucks up light from a room and will darken the area near the screen. If you have the area nearest the screen painted darkest, then ambient light won't impact the image as much and it will increase the overall quality of your projection experience.
Next comes shades. You can add any number of shades as you find best for the space. I recommend blackout shades with curtains. You can draw them as necessary, or just use one or the other for the results you desire.
Finally, don't ever use an open lamp!
Use directional lighting at all times. Ceiling can lights, wire lights with reflectors, floor lamps with reflectors that all point the light where you need it, not ones which direct light in every direction at once. You can add a lot of light to any theater space as long as you keep that light from shining directly on the screen and do a good job of controlling the reflections that fall onto the screen.
I put an example up here: http://www.avintegrated.com/lighting.html
All that said, you may still find you want a flat panel display for day-to-day viewing, and a projector for those moments when you really want the cinematic experience.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
