ideas / experience with stand for short throw projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-17-2013, 06:36 PM - Thread Starter
eladm's Avatar
Hi all,
I wanted to ask for your help / experience with a recommendation for a proper stand for a short-throw projector.
I simply couldn't find a stand / cabinet that could host a few components as well as a projector that needs to be located ~50" from the wall..
I actually went ahead and asked for a quote on a customer cabinet, one that will sit next to the back wall, and will have a stand reaching out from it to back to allow the projector to be located 50 inch away from the wall - but the prices they quoted were in the thousands.. much more than the whole A/V system!
Anyone with a short-throw projector that have already figured it out ? Or maybe there is an untapped market here, waiting for short-throw projectors to pick up in popularity ?
eladm is offline
post #2 of 7 Old 11-18-2013, 09:27 AM
AV_Integrated's Avatar
Quoted: 1105 Post(s)
Liked: 803
Don't count on it. Projectors are typically ceiling mounted, those who need it mounted in front of the screen are generally business travelers who just put it on a desk, or use a portable projection stand.
If it were me, I would go to www.racksandstands.com (Wayfair) and look at their equipment racks. The all wood ones often have a removable 'back' to them and adjustable shelves, so you can get a clear line of sight to the screen while still having a decent looking piece of furniture.
Any specific reason you don't ceiling mount?
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is online now
post #3 of 7 Old 11-18-2013, 10:23 AM - Thread Starter
eladm's Avatar
Wife doesn't allow it on the ceiling.. :confused:. Thanks for the advise, I am trying to see if I can find a cabinet on wheels (or put one on wheels myself) so that it will stand next to the wall when we dont use it, and be wheeled 4 feet back when we do use it.
Not optimal but good enough, I guess..
eladm is offline
post #4 of 7 Old 11-18-2013, 11:15 AM
Sonyad's Avatar
Quoted: 190 Post(s)
Liked: 111
Wire cart, microwave cart, printer cart couldn't work?
Sonyad is online now
post #5 of 7 Old 11-18-2013, 12:12 PM
milt9's Avatar
Ikea has a lot of cabinets
milt
milt9 is offline
post #6 of 7 Old 11-18-2013, 10:02 PM - Thread Starter
eladm's Avatar
thanks. just a simple cart would look out of place in the living room as well as expose all the cables coming in and out of the projector.. I do think about adding wheels to a medium size cabinet, and take it to and from the wall. Will need to test this out though, and see how cumbersome or not this will be.
eladm is offline
post #7 of 7 Old 11-19-2013, 05:49 AM
Sonyad's Avatar
Quoted: 190 Post(s)
Liked: 111
If it has to match your living room aesthetically, you may be out of a lot of money. Ikea has some fabulous carts but if that doesn't match your living style that is also a problem. Have you thought about using a table cover to allow it to blend in when not in use?
