Epson 3010 blue glow in lower right corner - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-23-2013, 02:54 PM - Thread Starter
pixelens's Avatar
I have an Epson 3010 projector - it's been great so far! A couple months ago, I noticed that when I start it up there's a blue glow in the lower right hand corner. After a few minutes (no more than 5 or so), the glow dissipates. Does anyone know what is causing this and how to fix it? I've had it for almost 3 years so it's out of warranty.
IMG_20130808_204647.jpg 69k .jpg file
IMG_20130808_204658.jpg 71k .jpg file
IMG_20130808_204714.jpg 75k .jpg file
ID:	73529   Click image for larger version
ID:	73530   Click image for larger version
pixelens is offline
post #2 of 5 Old 11-24-2013, 08:15 PM
szitzma's Avatar
I've got the exact same thing on my Epson 3010 in the lower right corner when I power on the projector, and it goes away after a few minutes.
I've had the projector since 11/2011 and it's got just over 1400 hours on it.
Scott
szitzma is offline
post #3 of 5 Old 11-24-2013, 11:44 PM
adude's Avatar
Quoted: 51 Post(s)
+1. I have the same issue. I noticed it about a month ago. Since it goes away after some time, didn't pay much attention to it.
adude is offline
post #4 of 5 Old 11-27-2013, 10:18 AM - Thread Starter
pixelens's Avatar
Glad to see that I'm not the only one with the issue. I just emailed Epson support about this issue, I'll see what they come back with response wise and update here.
pixelens is offline
post #5 of 5 Old 11-27-2013, 04:44 PM - Thread Starter
pixelens's Avatar
This is the response I got from Epson:
It is not uncommon to see discoloration in the image when the projector is warming up. The most common is a greenish hue that can appear when the projector first powers up and goes away after the unit has warmed up. What you are describing would have more to do with the optical engine and not the lamp. The lamp is only the light source and is primarily responsible for brightness. It does not produce actual colors or images.
Richard M.
pixelens is offline
Epson Powerlite Home Cinema 3010 2d And 3d Projector V11h421020
