Replacing an Epson Allen wrench - AVS Forum | Home Theater Discussions And Reviews
Old 12-08-2013, 10:58 AM - Thread Starter
retired4now's Avatar
My apologies for starting a thread so 'trivial', but I could not find another thread that is appropriate.
My old Epson 9500UB projector is ceiling mounted using the included mount ELPHB800, and I realized that I have lost the included Allen wrench. It is non-standard (it has a round hole in the middle, instead of being solid). Can this be purchased, or is there something equivalent that I can purchase?
retired4now is offline
Old 12-08-2013, 11:33 AM
RPS13's Avatar
Liked: 31
Like this:
What you're looking for is called a "tamper resistant allen wrench." Measure across the flats for the right size.
Kinda odd they'd use tamper resistant bits though.
Or is it this?
Whch is known as a Torx bit/wrench.
retired4now likes this.
RPS13 is offline
Old 12-08-2013, 12:36 PM - Thread Starter
The top photo looks like what came with the mount (an L shape one). I don't see this in the local hardware stores like home depot, but it is available online.
I am hoping to move the projector to another room in time for Christmas, so this is a big help. Thanks!
Old 12-08-2013, 06:34 PM
RPS13's Avatar
Liked: 31
You can always try to vise grip off the old allen bolts and replace them with the same thread size and pitch. It's likely metric, but every once in a while you get surprised with imperial hardware these days.
RPS13 is offline
