$1000 projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 12-13-2013, 03:23 PM - Thread Starter
pLuhhmm's Avatar
*Epson V11H561020
*Optoma HD25e
*Optoma hd131xe
*BenQ W1070
*Mitsubishi HC4000
*Mitsubishi HC7900DW
Front runners: Optoma hd131xe VS Mitsubishi HC7900DW
Is there anything better for $1k than the Mitsubishi HC7900DW?
It's going to go in a basement so light is controlled. About 100" screen size.
pLuhhmm is offline
post #2 of 15 Old 12-13-2013, 03:38 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
What is your throw distance for the projector? Do you have flexible placement options? Do you care about 3D?
pLuhhmm likes this.
ack_bk is offline
post #3 of 15 Old 12-13-2013, 03:41 PM - Thread Starter
pLuhhmm's Avatar
I think 15 feet at least?
It's a rental house so not really.
I can leave or take it. so not really.
pLuhhmm is offline
post #4 of 15 Old 12-13-2013, 04:06 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Are you planning on mounting this to the ceiling and running cables?
At any rate the Optoma 25e is going to be too bright IMHO for a 100" screen unless you have tons of ambient light in the room.
The Mitsubishi HC7900 has vertical lens shift. What this means is that it will be much easier for placement options and easier to mount. For a 100" screen it should have plenty of lumens and a 15' throw works well with this projector on a 100" screen:
http://www.projectorcentral.com/Mitsubishi-HC7900DW-projection-calculator-pro.htm
The BenQ1070 has more limited lens shift in that is has vertical lens shift only. That means you will need to align the projector to the center of the screen perfectly to avoid using keystone:
http://www.projectorcentral.com/BenQ-W1070-projection-calculator-pro.htm
The Optoma 131Xe is going to be brighter and make work the best if you plan on watching if there is light in the room at all. That said, it has no lens shift. That means you need to have more flexibility in terms of where you place the screen and the projector to align them properly:
http://www.projectorcentral.com/Optoma-HD131Xe-projection-calculator-pro.htm
I own the Optoma and love it, and it is the cheapest of the projectors listed. Being honest, I would probably go with the HC7900DW only due to the smaller screen size (100" diagonal) and the lens shift option which gives you more placement flexibility. On the downside Mitsubishi is leaving the projector market. They will still honor their warranty, and it also explains the deal on this projector smile.gif
pLuhhmm likes this.
ack_bk is offline
post #5 of 15 Old 12-13-2013, 04:47 PM
rbye05's Avatar
Just for info i own the 7900 and it does not have horizontal lens shift as stated above just vertical however i love it and think its a steal at current prices
ack_bk and pLuhhmm like this.
rbye05 is offline
post #6 of 15 Old 12-13-2013, 05:01 PM - Thread Starter
pLuhhmm's Avatar
What's the downside to having horizontal?
pLuhhmm is offline
post #7 of 15 Old 12-13-2013, 05:11 PM
rbye05's Avatar
No downside to have it the downside of not having it is less placement flexibilty but most projectors in this price range dont have it
pLuhhmm likes this.
rbye05 is offline
post #8 of 15 Old 12-13-2013, 05:14 PM
rbye05's Avatar
Just to add vertical lens shift is usually the more critical one to have
rbye05 is offline
post #9 of 15 Old 12-13-2013, 11:25 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Thank you I thought it had horizontal shift as well. I corrected my post.
ack_bk is offline
post #10 of 15 Old 12-15-2013, 05:08 PM
jebuzz's Avatar
Any better projectors than the Mitsubishi HC7900DW for $1000? Outside light is a non issue. Seems like the best value.
jebuzz is offline
post #11 of 15 Old 12-15-2013, 05:23 PM
aab1's Avatar
Quoted: 49 Post(s)
Where are you guys seeing the Mits HC7900DW for $1000? It's around $1800 everywhere I checked so far.
aab1 is offline
post #13 of 15 Old 12-15-2013, 08:00 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
$899 once you add it to your cart here:
Also an authorized dealer.
http://www.projectorpeople.com/Mitsubishi-HC7900DW/Projector/27782
ack_bk is offline
post #14 of 15 Old 12-15-2013, 09:08 PM
Skrill's Avatar
Quoted: 246 Post(s)
Liked: 73
How much lens shift is available on this Mitsu projector? It seems to be pretty low, or am I reading the throw calculator on the website wrong? I will have 103" high ceilings (8' 7"). Assuming 5" for a low profile mount, the projector top would be 98" (or a bit over 8' high). The calculator tells me that I need to mount my screen (120") -- 15" below the top of the projector, even with lens shift activated. Is that right? This would be my first projector -- so please tell me if I am screwing something up. Placement would be in a dedicated theater with full light control (no windows).
http://www.mitsubishielectric.com/bu/projectors/calculations/prjcalc.html?p=hc7900dw
Skrill is offline
post #15 of 15 Old 12-17-2013, 03:26 AM
aab1's Avatar
Quoted: 49 Post(s)
I was trying to figure out the same thing because I plan to have the screen come down over a desk that's 30" tall and want to make a 106" screen that''s 52" tall with 93" ceiling leaving me with 11"of play. According to the manual, it seems like for a 100" screen by default would be 16" below the lens, but at the "highest" lens shift it's 7" less which makes 9". I was planning on screwing a 1/2" thick piece of wood between the joists and have the projector screwed onto the piece of wood to have it as close to the ceiling as possible as well as screwed into joists.
http://www.mitsubishielectric.com/bu/projectors/downloads/pdf/hc7900dw/hc7900dw_manual.pdf
I'm still deciding what model to get as my 7 year old Sharp DT-510 is dying (I've brought the color wheel back to life 3 times so far by lubricating it and/or soaking the color wheel and motor in 70% alcohol). The HC7900DW is very tempting, both my previous projectors I had got a similar deal where a previously much more expensive projector when on sale for a faction of the original price, I prefer this to getting a low end model of similar price.
My current projector makes a 78" image and is 1000 lumens and it's more than bright enough to be viewable with the lights on, would the HC7900DW making a 106" screen be about the same brightness as my 1000 lumen projector with a 78" screen?
Are there any cons to the HC7900DW I should know about? Is the dynamic iris something that ends up failing like color wheels after several years?
aab1 is offline
Benq W1070 3d Ready Dlp Projector 1080p Hdtv , Optoma Hd25e 2800 Ansi Lumens 3d Home Theater Projector , Optoma Hd131xe Dlp Projector 3d , Mitsubishi Hc4000 300 Inch 1080p Front Projector , Mitsubishi Hc7900dw Home Theater 3d Projector
