Optoma h180x - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-28-2013, 01:29 AM - Thread Starter
jost's Avatar
Hi, I am new to projectors, what do you think of the h180x or maybe you could suggest something similar in that price range?
jost is offline
post #2 of 3 Old 12-28-2013, 05:57 AM
southpaw85's Avatar
Quoted: 86 Post(s)
Liked: 43
The benq w770st is only 529.99 on amazon. I have it and it is excellent. I'm not the only one who thinks so. Amazon has overwhelmingly positive reviews, trusted reviews has a good review, and avforums (not avs) gives the non-short throw version (the w750) high marks.
southpaw85 is offline
post #3 of 3 Old 12-28-2013, 09:58 AM
AV_Integrated's Avatar
Quoted: 1148 Post(s)
Liked: 825
I think the H180X will be the 'cheap' projector to get for people.
http://www.projectorcentral.com/Optoma-H180X.htm
At a similar $500 price point it offers one of the most comprehensive packages around.
The W770ST is certainly a worthwhile competitor out there:
http://www.projectorcentral.com/BenQ-W770ST.htm
On paper, the Optoma has slightly better contrast and is slightly quieter, but both are similar models overall and I would expect similar performance.
The biggest difference is the throw distance, and it is just reality that longer throw projectors produce a bit better of an image. If you aren't using a fixed frame screen and have any potential to bowing or waves in the screen, the longer throw of the Optoma will be a very important feature.
But, both should be expected to produce very good images on screen for a great price. The big limitation with both is the 1280x720 resolution, which begs the question of whether or not you can't muster up $300 more for a 1920x1080 projector.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
Optoma H180x Dlp Projector 3d , Benq W770st 3d Ready Dlp Projector 720p Hdtv 16 9 1280x720 Hd 720 13000 1 2500 Lumens Hdmi Usb Vga I
