Advice needed On Portable Projector For Movies $600 budget - AVS Forum | Home Theater Discussions And Reviews
Old 01-05-2014, 10:13 PM - Thread Starter
payj's Avatar
Hello,
I recently just a got a new MB Air and would like to get a projector that is portable enough for travel that I can link to it when I go to my summer place. I had been reading pretty good things about the ML550 on other sites and also the PA75U. The PA75U is too big though. The ML550 seems to be the max size I would like to go.
So is there something better that size or smaller in the 500-600 range?
The main focus will be movies and gaming
Thank You!!
payj is offline
Optoma Ml550 Wxga 500 Led Lumens Mobile Projector , Lg Pa75u Dlp Home Theater Projector
