Optoma HD33 squares of color - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-11-2014, 09:36 PM - Thread Starter
sombershin's Avatar
Hey all--
I've started having a strange issue with my Optoma HD33, and was curious if anybody had seen something like this:
That's a picture taken of the projector output with the brightness pushed up to make the issue clearer. This started happening a few weeks ago. The projector is 1.5 year old, with about 250 hours on the lamp. I've tried different inputs and cables and the problem is definitively the projector. What's particularly curious is that the color splotches are not fixed in place with respect to the projector, but with respect to the projected image. That is, if I move the photograph or whatever that's being projected around on my computer the image coloration stays the same. This makes me think it's some sort of decoding issue on the projector software side.
Anybody have an idea?
sombershin is offline
post #2 of 3 Old 01-13-2014, 04:57 PM
rekbones's Avatar
Quoted: 407 Post(s)
Liked: 196
Does it happen with other output devices such as a Blu Ray player. If so then try doing a full reset on the projector it has been known to solve other corrupted firmware issues. If not I would suspect the video card in computer.
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
post #3 of 3 Old 01-13-2014, 10:12 PM - Thread Starter
sombershin's Avatar
Yep, the problem occurs with multiple, known-good input sources. Full reset doesn't fix it.
Oh well, probably going to have to send it in for service.
