Epson 8700 vs BenQW1070 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-13-2014, 04:27 AM - Thread Starter
chevytwonova's Avatar
I have an opportunity to get an Epson 8700 for 700 Dollars with a brand new lamp that has never been installed (epson) or i can buy the W1070 new. Any suggestions on this?
chevytwonova is offline
post #2 of 2 Old 01-13-2014, 03:30 PM
rekbones's Avatar
Quoted: 290 Post(s)
Liked: 142
For an Epson 8700 in good working order $700 is a good price. Does it have any warranty, can you see it run before purchase, can you do without 3D, do you need the excellent lens shift, is the new bulb an OEM lamp and how many true hours on the projector ? If you can answer most of those questions with a yes than its a good buy. The BenQ is a sure thing. Used LCD's with high hours on them tend to have blue panel/diffuser failures and are prone to dust blobs and/or convergence issues. Also some have been known to have short lamp lives.
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Denon 1912 AVR, 7.1 with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is online now
Benq W1070 3d Ready Dlp Projector 1080p Hdtv , Epson Home Cinema 8700 Ub Projector
taboola here
