Projector Guidance for Basement Theater (Epson 5010/8350 or Panasonic AR100U) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-23-2014, 07:59 PM - Thread Starter
nmjwolf's Avatar
A little background. I need a projector for my basement the room is ~17x24 (8.5' ceilings) that I will be using as a bar/theater room. We will be watching 40% TV/Sports, 40% movies, 20% or less games. The room has one window in the back of the room, but it is located under a deck so the ambient light is very low. I plan on doing a 110 DIY screen.
I have been thinking that the seating (couch for now) should be ~12 feet from the screen, does this sound reasonable? We would like to watch sports with lighting ect, so I think lumens is important.
The projectors that i am considering are a refurbished Epson 5010 a refurbished Epson 8350 or a Panasonic PT-AR100U. Most of the viewing will be done in 2D.
I am leaning toward the 5010, but would like to hear your opinions.
nmjwolf is offline
post #2 of 7 Old 01-24-2014, 09:46 AM - Thread Starter
nmjwolf's Avatar
Anyone?
nmjwolf is offline
post #3 of 7 Old 01-24-2014, 09:57 AM
AV_Integrated's Avatar
Quoted: 978 Post(s)
Liked: 721
Why not brand new models? Are you sold on using LCD? Have you looked at the top 3 'cheap' models right now in the Epson 2030, BenQ W1070, or Optoma HD25? For gaming, the BenQ and Optoma will do best and will have superior black levels and motion handling than most of the LCD models, except, perhaps, the 5010 which is a higher class of projector.
Always be aware, of warranties and potential issues with any gear you buy which isn't new.
12' seating to a 110" diagonal is 'center of theater' in feel and is the minimum size I would recommend.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is online now
post #4 of 7 Old 01-24-2014, 11:41 AM - Thread Starter
nmjwolf's Avatar
I think the warranty issue should be ok the B stock Epson's from authorized dealers have 2 year warranty. The lag shouldn't matter as all of the games are going to be for the kids.
nmjwolf is offline
post #5 of 7 Old 01-24-2014, 04:10 PM
Quoted: 978 Post(s)
Liked: 721
The 5010 or one of the models I previously listed are the ones to consider most.
post #6 of 7 Old 01-29-2014, 11:35 AM - Thread Starter
nmjwolf's Avatar
Ok just got the 5010 -- I like it.
After having the projector setup on ladder I realize that 110" screen is not big enough.
I want to go ~135", which puts the projector at 15' with a zoom of 1.8x, 17FL -- Does anyone see issues with this mounting setup?
nmjwolf is offline
post #7 of 7 Old 01-29-2014, 01:07 PM
Quoted: 978 Post(s)
Liked: 721
No issues at all!
If that size is comfortable to you, then that's a good way to go. Consider a 1.3 or 1.4 gain screen to get a bit more oomph out of the brightness long term, but certainly, no rush on that.
Epson 5010 Powerlite Home Cinema 3d Front Projector , Epson Powerlite Home Cinema 8350 , Panasonic Pt Ar100u Lcd Projector Pt Ar100u , Epson Powerlite Home Cinema 2030 3lcd Projector , Benq W1070 3d Ready Dlp Projector 1080p Hdtv , Optoma Hd25 Hd 3d Home Theater Projector
