Best Ceiling Mount for Epson 8350 - Please suggest - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-24-2014, 05:33 AM - Thread Starter
mirage1000's Avatar
Hello - I have an Epson 8350 that I would like to Mount to the ceiling.
what is the best mount I can get without breaking by bank.
Thanks in advance for your inputs and suggestions.
mirage1000 is offline
post #2 of 6 Old 01-24-2014, 07:21 AM
Mr.G's Avatar
Quoted: 684 Post(s)
Liked: 382
Read here:
http://www.avsforum.com/t/1280137/the-offical-epson-8350-owners-thread/8220#post_23520695
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #3 of 6 Old 01-24-2014, 07:33 AM
Topher's Avatar
Mine came with a Sanus VMPR1-03 & it works quite well.
Topher is offline
post #4 of 6 Old 01-24-2014, 08:42 AM
AV_Integrated's Avatar
Quoted: 1095 Post(s)
Liked: 794
Almost any mount 'works'. They can be tough to square to a wall, move a bit when you try to tighten them, and be poorly built overall, but they 'work'. If you want a GOOD mount, then the best I've seen is the Chief RPM series Elite mounts. The RPMU or RPMAU is the best mount on the market, but I'm guessing it will 'break the bank'. Of course, unlike projectors, you only need to buy one universal projector mount in your entire life. Kind of like a good screen, it makes more sense to put money into technology that won't be changing vs. technology that changes every year.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #5 of 6 Old 01-24-2014, 03:08 PM
niccolo's Avatar
Quoted: 141 Post(s)
Liked: 39
You could also save some money by going with a Chief RSM instead of RPM, it's identical but about 2/3 the size (and holds half the weight). Here's the best price I found on that: http://www.thefinalclick.com/Chief-RSMAU-Universal-Mini-Elite-Projector-Mount--Black_p_86403.html
EDIT: Actually, only a $15 difference, so the question is whether you want a heftier mount to be able to accommodate potential larger projectors in future, or something a little more compact.
Benq W1070 projector w/ Chief RSM mount with custom interface bracket
119" Da-Lite Cinema Contour with High-Contrast (gray) Da-Mat screen
Denon X2000 receiver fed by Panasonic DMP-BDT210 Bluray player
Focal Chorus 700-series towers and center, JMLab Tantal 500-series bookshelf rears
Rythmik FV15HP sub
niccolo is offline
post #6 of 6 Old 01-24-2014, 03:21 PM
Liked: 794
eBay is always my go to...
http://www.ebay.com/itm/Chief-Security-Projector-Mount-/231111807198?pt=US_Projector_Mounts_Stands&hash=item35cf5650de
$110 shipped.
Epson Powerlite Home Cinema 8350
