Optoma HD25e for 890$ vs Optoma X131e for 720$ - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-27-2014, 10:15 AM - Thread Starter
humblebeing's Avatar
Is the difference worth the 150$ gap?
humblebeing is offline
post #2 of 3 Old 01-27-2014, 06:58 PM
farhan_ds's Avatar
Yes if you plan to keep your buget lower and spend on some 3d glasses as well..
.. and No..if your store has a good return policy and warranty cover.. apparently few buyers have reported on online store review sections with focus issues on the 131xe with soft image throughout, on some sources like a 1080p PC input,, but if it is not an isue for you, or it works out fine out of the box, you have a good and almost identical proprietor for 150$ less and also black in color.... Shiny smile.gif
farhan_ds is offline
post #3 of 3 Old 01-28-2014, 05:41 AM
PM-Performance's Avatar
Quoted: 255 Post(s)
Liked: 146
I would try best buy for it. Seems like they may be newer than the online retailers.
No soft corners with mine and mine came with a lense cover. First I have heard of a lense cover coming with them so my guess is maybe a newer build?
Klipsch RF-82|RC-62|RS-52|RB-51, 2 Ultimax 18's in Marty Cabs Powered by Inuke 6000DSP|
Denon AVR-X4000|Oppo BDP-103|Epson 5020UB with Elite SableFrame 110"|
4 Aura Bass Shakers powered by Dayton PSA-250|4 Seatcraft 5131 seats
PM-Performance is offline
Optoma Hd25e 2800 Ansi Lumens 3d Home Theater Projector , Optoma Hd131xe Dlp Projector 3d
