Newbie needs help with settings - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-27-2014, 07:20 PM - Thread Starter
yankeept's Avatar
Just bought my first projector 3 days ago.  I  love the quality of the picture, but can't seem to fix a simple (I think) problem.  The picture is a perfect rectangle, but it appears there is an extra glare in the shape of a trapezoid around the picture.  When I use the keystone settings, I change the shape of the picture, but the 'other' trapezoid still remains.  What am I missing?  Sorry for my limited knowledge.  The projector is about 9.5' off the ground on a ledge & about 12.5' away from the wall.  Thanks in advance.  The SuperBowl is less than a week away.
yankeept is offline
post #2 of 4 Old 01-28-2014, 05:52 AM - Thread Starter
yankeept's Avatar
When I turn on the projector w/o the cable, there is a light outline of a trapezoid that is wider on the bottom.  Does this mean I need to somehow re-arrange the position of the projector.  It is about 9.5 ft off the ground on a ledge & angled down.  Thanks for any help as the Super Bowl gets closer & closer.
yankeept is offline
post #3 of 4 Old 01-28-2014, 07:18 AM
Luke Chara's Avatar
That will be the keystone correction, put your projector dead on with the screen for best results.
Luke Chara is offline
post #4 of 4 Old 02-04-2014, 08:52 PM - Thread Starter
yankeept's Avatar
For anyone that cares, I figured out the problem prior to the SuperBowl... The projector is sitting on a ledge about 9.5 ft off the ground.  I guess from that height it is designed to hang form the ceiling, not sit upright on a ledge.  Therefore I had to turn the projector upside down on the ledge & change the setting...Problem solved.
yankeept is offline
