$4000 budget benq or Panasonic? - AVS Forum | Home Theater Discussions And Reviews
Old 02-01-2014, 11:27 AM - Thread Starter
hemants's Avatar
Need 120" motorized screen for an open basement
Panasonic 8000 or
benq 1070 and put more $ in screen?
hemants is offline
Old 02-01-2014, 09:38 PM
farhan_ds's Avatar
even with the 8000 you can easily afford a motorised screen... your buget is plenty for a high end home theater.. even with the 8000..
8000 should have better colors than 1070..but depends on your choice of useage.. 8000 specifically for movies is superior than most of the projectors out there..
farhan_ds is offline
Panasonic Ptae8000u Hd Projector , Benq W1070 3d Ready Dlp Projector 1080p Hdtv
