Optoma 200x bulb just blew (POP!)... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-02-2014, 04:38 PM - Thread Starter
Favelle's Avatar
Just wondering how good/trustworthy are the $75 bulbs on fleabay? They look the same....but are they any good?
In terms of LFE, size does matter!
Favelle is offline
post #2 of 5 Old 02-03-2014, 08:31 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
You'll want something with an OSRAM bulb or OEM lamp to give you the best odds of one not self-destructing within a few months.
I don't think the Optoma 200X was intended for the U.S. market so you may not get much input here.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #3 of 5 Old 02-05-2014, 10:07 PM - Thread Starter
Favelle's Avatar
Thanks Mr. G.....does it matter if it comes with the housing or not? Is it a difficult process to install bare lamp?
Favelle is offline
post #4 of 5 Old 02-06-2014, 06:27 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
Doesn't seem to be but it would depend on the projector model. Follow the instructions that come with bulb.
Here is a sample link to a YouTube video on installing a bulb into a housing.
How to Install a Bare Projector Lamp into your Projector
Again it's up to you to decide if installing a bare bulb is preferable to buying an OEM manufacturer lamp.
Mr.G is offline
post #5 of 5 Old 02-19-2014, 06:29 PM - Thread Starter
Favelle's Avatar
Thanks man. Ended up going with an official bulb from Amazon.ca. For less than $180 it seemed like a good enough deal to extend my projector's life by 2-3 years.
Favelle is offline
Optoma Pro250x 2800 Lumen Xga Dlp Multimedia Projector
