EPSON 3010 - Left Edge Blue Glow, Right Edge Red Glow - Ideas? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By WindsorTheater
post #1 of 9 Old 02-08-2014, 11:23 AM - Thread Starter
WindsorTheater's Avatar
Purchased the unit used a couple of months ago. Worked flawlessly. Just started to notice in the last few weeks a blue glow the full height of the left side of the screen and a read glow the full height of the right edge of the screen.
Question is could this be bulb related, or something else that has failed / is failing in the projector. Given the unit is used I don't have confidence in the bulb life (says 300h but could have easily been reset).
Any guidance would be greatly appreciated.
WindsorTheater is offline
post #2 of 9 Old 02-08-2014, 03:42 PM
Tinman's Avatar
Liked: 33
Nothing is actually failing.
This is a common problem with LCD projectors. It is typically caused by the polarizer lens that comes after the lamp assembly. It moves a little out of alignment from the heating and cooling cycles.
This was not a problem before they made absolutely everything possible out of plastic.
However, it takes a bit of skill to reseat this lens, and it could move again with time.
Welcome to the darkside.....
Tinman is offline
post #3 of 9 Old 02-08-2014, 04:57 PM - Thread Starter
Thanks for the reply. Any online guides I could reference? I'm quite savvy (ie. fearless) in the area of electronics dis-assembly and repair but prefer a reference.
post #4 of 9 Old 02-09-2014, 02:13 PM - Thread Starter
How about it. Anyone ever take a 3010 apart and can offer some insight?
post #5 of 9 Old 02-25-2014, 09:28 AM
Donhou's Avatar
I have exactly same problem with my 8500ub as WindsorTheaters`s 3010..
So could fix discussed in this thread http://www.avsforum.com/t/1458911/epson-8100-replaced-bulb-and-now-pink-blue-bands/30 be a solution to this blueish/reddish bands both sides of the image also?
Donhou is offline
post #6 of 9 Old 02-25-2014, 12:16 PM
Tinman's Avatar
Liked: 33
Possibly, but it could also be the cinema filter that slides into the optical path.
Tinman is offline
post #7 of 9 Old 09-21-2014, 08:42 PM - Thread Starter
Thought I would update the community.
I successfully solved the red / blue halo's at the right and left edge of the screen by opening up the 3010 and re-seating the the first glass lens (or whatever it is) after the dynamic iris. I actually didn't even need to take the main circuit board out (but I did anyways). Could be done in about 30 minutes.
Project is back to the state when I received it (or better).
Thanks everyone for the tips.
Ftoast likes this.
post #8 of 9 Old 01-29-2015, 12:03 PM
Digidan's Avatar
I've got the blue glow bottom left corner, it goes away after 20 mins. I was going to just let it be until I get a new PJ, then I saw this thread. Are there any special hurdles I have to jump over once the cover is removed to get to that lens? and how difficult is it to remove and reseat it?
Dan Cisco
Mr. Negadelphia
Digidan is offline
post #9 of 9 Old 08-29-2015, 11:49 AM
The.Enraged's Avatar
I have the same left-pink, right-blue problem. I have 4000+ hours on it. And it just started happening a couple days ago. I'm on my second bulb wich was a non-epson one which I think runs hotter. I've gotten one over heating warning since replacing. I was going to attempt the fix, but also thinking of replacing the fan at the same time. Does anybody know the size of the fan?
The.Enraged is offline
Epson Powerlite Home Cinema 3010 2d And 3d Projector V11h421020
