Looking For a "Once In A While" Projector - $300 budget - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-12-2014, 04:33 PM - Thread Starter
jwh92020's Avatar
I'm looking for a used projector that will be for watching an occasional movie or sports event on a 92" pull down screen in our living room. That's why it will be a "once in a while" projector. The bulk of our movie watching is outdoors, but this winter has been a bit too cold. The wife agreed to the pull down in the living room because she doesn't like sitting in our heated garage to watch a movie (go figure?) Anyway, looking for something with HDMI input as I run wireless HDMI in the house, would like 720p and native 16:9. Like everyone else in multi purpose rooms, movies are in the dark, a small amount of ambient light for sports. I currently have an Infocus IN72 (900 lumens, 2000:1, 854 x 480). We watched the Superbowl and a couple of movies with it and it's ok+. Not quite GOOD, definitely not great. I'm thinking a bit more brightness and resolution would be much better. I found an INfocus IN78 (900 lumens, 3500:1, 720p) for $300 but that seems a bit high for that old of a projector. I know brightness won't increase with it but I thought that better contrast and resolution might make up for. Any suggestions will be most appreciated. Thanks BTW - the outdoor projector is a dedicated unit, it sits in a climate controlled projector "shed" in the back yard.
jwh92020 is offline
post #2 of 2 Old 02-12-2014, 05:23 PM
airscapes's Avatar
Quoted: 357 Post(s)
Liked: 289
Find yourself a used Mitsubishi HC3000 with low lamp hours, should pay no more than $250 for it. If lamp is almost done, no more than $150-175. Will be quieter than the 72, had one before the HC3000 and will be a big upgrade. OEM lamp is $300 but will last over 3000 hours.
I would sell you mine but I want to keep it for backup.. BTW I bought it over 4 years ago used for $175 and put in a new OEM lamp. still looks as good as it did 3500 hours ago.
Good luck~
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
Mitsubishi Hc3000u High Definition 720p Dlp Home Theater Projector
